Radiator support removal?
- Replies 14
- Views 13.6k
Mopar1973Man 5 posts
AH64ID 3 posts
angus 2 posts
dorkweed 1 post
Good choise. There is enough room to R&R it with the cab installed. IIRC it takes a bit of an angle during entry.
2nd head is closer to the cab, and I managed to do mine. I had to pull the valve cover and run a chain across the head very tight.
I'm curious if this radiator support cross brace has to be removed to remove the engine? If so how do you remove this cross brace? I've got the 8 bolts already lose in the picture. When I remove then the brace will slide a bit both ways but not enough to remove it.
