Dead fuel gauge
Does that mean the air bag was set off at one time or can it detect bumper benders too?
Never heard of 'Ethernet cable networks', how does that come into play,  not a tv network?  Hope I'm not asking a lengthy explanation on that one.
Edited by JAG1
Ok guys, newest development. My overhead display quit giving me a " distance till empty" reading, it's just says "SC" now. I've still got mileage and odometer and the rest of the stuff but not that. That reveal anything new?
Okay, when things go like this I have to try things on the list that's in square one/ back to basics.
Batteries have good clean connections
Low AC voltage emanating from the alternator when running
PCM grounding good clean to firewall
Pass battery to PCM ground good clean and tight. check the factory clip connection laying around the wheel well.
Take apart ground connections and look for corrosion.
Alternator grounding well thru its mounting bracket to engine block
ECM well grounded to block
Take off the ground to the engine block, the heavy cable going down below, and clean the lug and mate surface Theer might be two of them on the 24 valves.
22 hours ago, Mopar1973Man said:
Chrysler Crash Detection
This isn't like vehicle crash but data crash. It's built on the same design as ethernet cable networks.
I had the CCD come on a while back, I lost all gauges. it ended being a loose connection on the main plug on the PCM. got it snugged down and problem went a way. It was also throwing a code, I forgot what number but it related to a bad transmission circuit, between that and the CCD, I was really :think:
Ok jag I'll start knocking things off that list, and I'll check the main pcm plug also. I unplugged the three connections at the the pcm and cleaned them, and I cleaned the harness under the wheel well, all looked clean anyhow but I did them anyway.
10 minutes ago, Mopar1973Man said:
Weird one to check...
WARNING! - Please be careful with the bolt holding this plug it extremely easy to strip out.
The big plug in the PDC box has the CCD bus in that plug I wonder if the connection is poor or loose and creating issues.
Yep, that's the one I meant PDC box, not pcm, the big black/white one with bolt in center. And found out  thier is a fine line between snug and stripped
My 2 Cents.
The PCM continually monitors the fuel tank sending unit, then sends the proper messages to the
instrument cluster thru Chrysler Collision Detection (CCD) data bus.
Message Failure - If the cluster fails to receive
a percent tank full message, it will hold the gauge
needle at the last indication until a new message is
received, or until the ignition switch is turned to the
Off position, whichever occurs first.
// (CCD) data ID 37 Fuel Level Sensor.
// Tested on 2000 Dodge Durango PCM, 20 ohms - full <-> 240 ohms - empty
// Fuel ID 37~[HEX-25] (ID-DATA-CRC)
// DATA range 1 ~ 253 + Error handling, P0461, P0462 and P0463 are all related to the fuel level sending unit.
// If DATA equals 255: Error open-circuit, P0463 Fuel Level Sensor Circuit High Input
// If DATA equals 254: Range/performance, P0461 Fuel level sensor circuit range/performance.
// When is the code P0461 detected?
// The output signal of the fuel level sensor does not change within the specified range even though the vehicle has been driven a long distance.
// If DATA equals 0: Error short-circuit, P0462 Fuel Level Sensor Circuit Low Input.
// P0463 Fuel Level Sensor Circuit High Input
// @ 1Kohms to ∞ infinite resistance Ohms, (DATA equals 255) = Error open-circuit
// DEC: 37 255 36
// HEX: 25 FF 24
// P0461 Fuel level sensor circuit range/performance
// DEC: 37 254 35
// HEX: 25 FE 23
// P0462 Fuel Level Sensor Circuit Low Input
// @ 10 to 0 Ohms (DATA equals 0), Error short-circuit
// DEC: 37 0 37
// HEX: 25 0 25
// @ 240 Ohm empty.
// DEC: 37 1 38
// HEX: 25 1 26
// @ 220 Ohm nearly empty.
// DEC: 37 8 45
// HEX: 25 8 2D
// @ 180 ohm, before the low fuel light.
// DEC: 37 54 91
// HEX: 25 36 5B
// @ 179 Ohm, Fuel Reserve Light on (Data 53 to 1)
// DEC: 37 53 90
// HEX: 25 35 5A
// @ 20 ohm full
// DEC: 37 253 34
// HEX: 25 FD 22
That last post was probably extremely helpful, but not for my pea brain?.
Btw, tightening down the connector in the PDC seems to have removed the "ccd" error, I had it come on everyday for the past week multiple times and for 10 mins at a time. After tightening down that connector I have driven to straight days and haven't seen that error. So kudos for that suggestion!??
So does the fuel gauge work properly now?
2 hours ago, Me78569 said:
Mike,
I dont think the obd stuff will work,  you will need a CCD bus chip rather the obd stuff.   I think it is on a different protocol and buadrate.
That is correct.
The CCD bus protocol level is different, no public information is available.
You have to disassembling reverse engineering to find out how things work.
Nope, gauge is still dead  but the ccd on the overhead went away. Still no "dte" either. Im still making my way through jags list of suggestions on the grounds and plugs, knocked a few of them out today at lunch.
Thanks for the vote of confidence in my list. I'm a light weight electrical guy.
Have you found any corrosion or tainted connections?
The alternator grounds thru the mounting bracket. Being that it is painted I got the volt meter out and set it to OHMS and checked for resistance from alt housing to a clean unpainted surface on the engine. I found a noticeable degree of resistance on the meter. I was surprised as my engine is very clean and still looks new with only 85k miles.
After doing some reading about the importance in have a good alt ground helping to reduce AC noise and a general betterment of the DC system I installed a no. 8 wire and small lug terminal attached to an alternator housing bolt and back to the passenger battery ground. I don't know if it has helped but I know its a better ground and better protection for the more sensitive electronic circuits aboard. At least the batteries can do a better job of absorbing harmful AC noise.
Another thing I've noticed is I don't have any white powder corrosion on the battery terminals any longer, which used to be aggressive.
I wish I could be more helpful anyway.
Edited by JAG1
Only one corroded ground so far, ( driver battery ground) my truck only has 83,000 on it now, it's the cleanest 2nd gen I've seen, especially living out here in md where everything is rusted to hell!
You and me are about the same miles :thumb1: mines clean too.
Have you checked the alternator ground bracket for resistance? I good ground there helps reduce PCM confusion from AC noise..
Edited by JAG1
