- Replies 24
- Views 5.5k
leathermaneod 10 posts
dripley 4 posts
Haggar 4 posts
Mopar1973Man 2 posts
I would say the door is off. You can adjust them some by loosening the door to hinge bolts (not the hinge to body bolts) but be warned they can be a royal pain to align. To get all the gaps right and
Check your hinges, that looks like mine before I rebuilt the hinge pins and bushing.
most auto part stores have hinge pin sets. You have to support the door and grind off the top of the pin with a dremel and knock it out the bottom and if the bushing are still there get them out, rep
Hey all,
Looking at this pic, which do I need to adjust, the fender or the door? You can't see from this angle, but the fender also stick out past the door slightly. Yes I know I have rust that needs fixed lol debating wether to fix or replace the fender.
