- Replies 49
- Views 10.1k
Cummins2001 20 posts
SASQCH 9 posts
Mopar1973Man 6 posts
JOHNFAK 5 posts
Ok. I see you guys say 20-15 psi on fuel pressure is good. I got some gauges and it reads 10psi at idel and 5-6psi WOT. I thought maby I hooked up the gauge wrong and so I did it again and I am sure its right. Now what do I need to do. Truck never studders and starts good hot or cold. Truck runs good really if I did not have gauges I would not be able to tell the difference. I dont want to run the VP low on fuel since that all that lubs it. What should I do?
