- Replies 14
- Views 11.5k
Mopar1973Man 4 posts
Silverdodge 3 posts
KATOOM 2 posts
Me78569 2 posts
Stock head needs work before you would see gains.
Forced induction engines tend to not benefit from intake modifications as everything is essentially being "shoved" in by the turbo or supercharger. They do though respond to exhaust side work as the
Think of it this way..... Just remember that the air traveling through the horn dumps (literally) downward into the front 1/3 side of a long flat intake manifold. After that incoming air slams off a
Does an aftermarket intake horn that is 3 or 3.5 make a difference in egt or is the stock head More of a restriction or is the air to air I'm curious
