Quadzilla V2 Custom Tunes
I feel that it is time to start building a list of tunes that we all use.
Please learn what each tuning variable does.  There V2 tuning article covers everything in depth along with a video explaining each item.
This tool will allow you to edit Quadzilla tunes from your PC.
Update 1/15/17 V2.2 tunes should include timing maxes for various RPM's and fuel load timing
Copy this into your post and fill out the info
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Light Throttle Timing Load Limit:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Minimum Pump Tap Fueling Percentage:
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
7 x.009 DFI injectors, he351ve arduino controller
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Light Throttle Timing Load Limit: 30
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Minimum Pump Tap Fueling Percentage:0
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Minimum Pump Tap Fueling Percentage:15
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Minimum Pump Tap Fueling Percentage:10
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
@Carbur8tr For your towing tune.
lvl's I like 6 because I don't like having to push the plus button 1000 times.  but you can set this to whatever you like
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 365.2k
  • Quadzilla Power
    Quadzilla Power
    Not at this point. We are working on something that will enable measureing those as well but we don't have them in production yet. It will be some time.  -thanks again,
  • yep, most complain coming to V2 tuning because they are used to the butt dyno telling them "WOW I just touch the throttle and it jumps out of it's own skin"       what people don't consider
Looks good, the only thing I'm thinking is maybe go up a little bit on the TPS minimum to keep from using so much of the pump. It's good for the power when I need it, but otherwise would probably hurt mileage a bit since I would be using a bit more throttle while pulling.
Thoughts?
Daily drive tune low altitude:
Fuel Load timing: 2
Light Throttle Timing Adv:3
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Maximum Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min: 20
Boost Scaling: 35
RPM Limit: 3700
Power Reduction: 70
0 PSI %: 97
1 PSI %: 97
2 PSI %: 98
3 PSI %: 99
4 PSI %: 100
5 PSI %: 101
6 PSI %: 102
7 PSI %: 103
8 PSI %: 105
9 PSI %: 107
10 PSI %: 110
11 PSI %: 113
12 PSI %: 116
13 PSI %: 119
14 PSI %: 122
15 PSI %: 125
16 PSI %: 126
17 PSI %: 127
18 PSI %: 128
20 PSI %: 129
22 PSI %: 130
24 PSI %: 131
26 PSI %: 132
28 PSI %: 133
30 PSI %: 134
Edited by Me78569
Adding a tune.
@Me78569 I think it's crucial that we also put the major modifications in the post too. That was someone can find a setup close to theirs and use that to tune. Also missed the Max Fuel Stretch
300 hp injectors, 62/75 twins, SBDD with G56
My DD tune. Usually doesn't come above level 2 unless I need to get moving.
Power Levels: 11
Fuel Load timing: 2
Light Throttle Timing Adv:4
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Maximum Fuel Stretch: 1200
TPS Pump max: 99
TPS Pump Min: 50
Pump Low Boost Scale PSI: 25
Boost Scaling: 35
RPM Limit: 3700
Power Reduction: LOW
0 PSI %: 69
1 PSI %: 70
2 PSI %: 71
3 PSI %: 72
4 PSI %: 73
5 PSI %: 75
6 PSI %: 77
7 PSI %: 79
8 PSI %: 81
9 PSI %: 83
10 PSI %: 85
11 PSI %: 87
12 PSI %: 89
13 PSI %: 91
14 PSI %: 93
15 PSI %: 95
16 PSI %: 97
17 PSI %: 99
18 PSI %: 100
20 PSI %: 100
22 PSI %: 100
24 PSI %: 100
26 PSI %: 100
28 PSI %: 100
30 PSI %: 100
Edited by Me78569
Thoughts?
I would leave wiretap TPS low as if it is too high you will feel wiretap ramp up VERY quick once it comes on.  If you are concerned about wiretap at cruise sucking down fuel just leave it on lvl 3.   I would do that regardless, but I dunno if lvl 3 is enough fuel for you or not.
@Dieselfuture
here is a tune I would try
Quote
Power Levels: 6
Fuel Load timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1550  ** turn this up if you need more power up top
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3400
Power Reduction: 25 ( truck might not really idle this low)
0 PSI %:98
1 PSI %:98
2 PSI %:99
3 PSI %:100
4 PSI %:101
5 PSI % 102
6 PSI %:104
7 PSI %:106
8 PSI %:108
9 PSI %:110
10 PSI %:114
11 PSI %:118
12 PSI %:122
13 PSI %:124
14 PSI %:126
15 PSI %:128
16 PSI %:130
17 PSI %:132
18 PSI %:134
20 PSI %:136
22 PSI %:138
24 PSI %:140
26 PSI %:140
28 PSI %:140
30 PSI %:140
If it is lazy off the line and smoke free, try bumping your starting point by a few %
Edited by Me78569
I noticed a lot of you guys have your Pump Low Boost Scale PSI: at 0  ,is that ok
So much to learn but I'm loving it.
Edited by Dieselfuture
Low boost scale give you a 0-100% of how much wiretap you want before you reach the pump low limt.  I changed it to be % rather than PSI as that was confusing.
If you set this at 0 it iwll give you no wiretap until you hit the psi in the setting above it, in this example 8 psi.  at 8psi you will get 1/3 of the difference between your setting, 0 in this example, and %100.  At 11 psi you will get 2/3 and 14 psi you will get 3/3
If you had your low limit % set to 25 then you would get 1/3 or 75% ( 100-25 = 75)
I'm running only 6* of timing. Then my low boost scale is set for 25%. I've taken a stock tune and tweaked it to my own liking.
Power Levels: 7
Fuel Load timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1400  ** turn this up if you need more power up top
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 38
RPM Limit: 3200
Power Reduction: 5 (Barely pulls at 5 MPH great security feature)
0 PSI %: 100
1 PSI %: 102
2 PSI %: 104
3 PSI %: 106
4 PSI %: 108
5 PSI %: 110
6 PSI %: 112
7 PSI %: 114
8 PSI %: 116
9 PSI %: 118
10 PSI %: 120
11 PSI %: 122
12 PSI %: 124
13 PSI %: 126
14 PSI %: 128
15 PSI %: 130
16 PSI %: 132
18 PSI %: 134
20 PSI %: 136
22 PSI %: 138
24 PSI %: 140
26 PSI %: 142
28 PSI %: 144
30 PSI %: 146
Edited by Me78569
Looking for some input on helping me get my quad set for better Mpg. Currently I get 13-14mpg weather I am running around town or Hwy (75-80mph could be part of my problem).
Power Levels: 6
Fuel Load timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 9
Boost Scaling: 40
RPM Limit: 3200
Power Reduction: 93
PSI %: 93
PSI %: 93
PSI %: 95
PSI %: 96
PSI %: 97
PSI %: 98
PSI %: 99
PSI %: 100
PSI %: 101
PSI %: 103
10 PSI %: 107
11 PSI %: 111
12 PSI %: 115
13 PSI %: 116
14 PSI %: 117
15 PSI %: 119
16 PSI %: 121
18 PSI %: 124
20 PSI %: 124
22 PSI %: 124
24 PSI %: 124
26 PSI %: 124
28 PSI %: 124
30 PSI %: 124
Edited by Me78569
Power Levels: 6
Fuel Load timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3200
Power Reduction: 93
PSI %: 93
PSI %: 93
PSI %: 95
PSI %: 96
PSI %: 97
PSI %: 98
PSI %: 99
PSI %: 100
PSI %: 101
PSI %: 103
10 PSI %: 107
11 PSI %: 111
12 PSI %: 115
13 PSI %: 116
14 PSI %: 117
15 PSI %: 119
16 PSI %: 121
18 PSI %: 124
20 PSI %: 124
22 PSI %: 124
24 PSI %: 124
26 PSI %: 124
28 PSI %: 124
30 PSI %: 124
You're missing the most crucial variable.... cruise timing advance. I'm not seeing it here.
You're also missing the timing reduct.
Edited by Me78569
On your Iquad app reselect your truck, that wll load the update for the variables needed.  Once your custom tune shows the missing timing stuff I am sure your MPG will come up.
You are correct about the settings. I have updated them and we will see what happens
you should see timing jump to whatever you have your setting at when mph is stable above ~40 and tps is stable between `15-40%
Does it meter if you use cruise control, on my truck it shows 0 for tps because cruise is electronic
Cruise control is working for late year trucks.  Took a lot of time to get figured out but it is working.
Power Levels: 7
Fuel Load timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 38
RPM Limit: 3200
0 PSI %: 100
1 PSI %: 102
2 PSI %: 104
3 PSI %: 106
4 PSI %: 108
5 PSI %: 110
6 PSI %: 112
7 PSI %: 114
8 PSI %: 116
9 PSI %: 118
10 PSI %: 120
11 PSI %: 122
12 PSI %: 124
13 PSI %: 126
14 PSI %: 128
15 PSI %: 130
16 PSI %: 132
18 PSI %: 134
20 PSI %: 136
22 PSI %: 138
24 PSI %: 140
26 PSI %: 142
28 PSI %: 144
30 PSI %: 146
Good lord this is an aggressive curve.  How quickly does the power come in and do you haven any issues with smoke below 10 PSI?
Edited by Me78569
Just a light puff just as the wire tap hits then clears right up. I might bump the wire tap back to 10 PSI. Pulls like a mule getting on the interstate. Gotta be careful it's been known to break the tires loose getting to the top end of 3rd gear.
:lmao: pizza cutter life
I'm going to make a tune tonight up to 140% and see if I can make it smoke free. @Me78569 your wish is my command.
Hahahaha there are actually a few lines of code in the new tuning commented with Tyler's wish is my command....
Also really anything over 125-130% up top will max out the fueling message.  The ECM can and will ask for a fuel message of 3600.
There is very little difference is size.
Width 1.1" inches narrow, Height it's 0.04" taller. But the key feature is 235's are 23-25 pounds lighter! Only 1 rev/mile difference. Way less rotational mass.
