I feel that it is time to start building a list of tunes that we all use.
Please learn what each tuning variable does.  There V2 tuning article covers everything in depth along with a video explaining each item.
This tool will allow you to edit Quadzilla tunes from your PC.
Update 1/15/17 V2.2 tunes should include timing maxes for various RPM's and fuel load timing
Copy this into your post and fill out the info
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Light Throttle Timing Load Limit:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Minimum Pump Tap Fueling Percentage:
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
7 x.009 DFI injectors, he351ve arduino controller
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Light Throttle Timing Load Limit: 30
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Minimum Pump Tap Fueling Percentage:0
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Minimum Pump Tap Fueling Percentage:15
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Minimum Pump Tap Fueling Percentage:10
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
@Carbur8tr For your towing tune.
lvl's I like 6 because I don't like having to push the plus button 1000 times.  but you can set this to whatever you like
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 274.5k
  • Quadzilla Power
    Quadzilla Power
    Not at this point. We are working on something that will enable measureing those as well but we don't have them in production yet. It will be some time.  -thanks again,
  • yep, most complain coming to V2 tuning because they are used to the butt dyno telling them "WOW I just touch the throttle and it jumps out of it's own skin"       what people don't consider
3 minutes ago, Me78569 said:
Hahahaha there are actually a few lines of code in the new tuning commented with Tyler's wish is my command....
Also really anything over 125-130% up top will max out the fueling message.  The ECM can and will ask for a fuel message of 3600.
Every now and then I have a decent idea! Glad my name is stuck somewhere haha. Got the tune made. If it's pretty clean I'll post it up.
4 minutes ago, Mopar1973Man said:
There is very little difference is size.
Width 1.1" inches narrow, Height it's 0.04" taller. But the key feature is 235's are 23-25 pounds lighter! Only 1 rev/mile difference. Way less rotational mass.
Those are right at 2" narrower than the tires I have. Wider tires do help keep the rubber stuck on the pavement. I don't break the tires loose often with 200+ more hp.
Had to go with taller tires on mine to get the revs down. Early G56 OD ratio isn't the best IMO
235mm = 9.25
265mm = 10.43
10.43 - 9.25 = 1.18 inch difference. Math doesn't lie...
235mm x 85% = 199.75mm
265mm x 75% = 198.75mm
199.75 -198.75 = 1.00mm difference in height... Math doesn't lie...
6 minutes ago, Mopar1973Man said:
235mm = 9.25
265mm = 10.43
I've got 285's, which are 11.2205" wide.  1.96853" wider than 235's
My sidewall height is 199.5mm or 32.708" from top to bottom.  (285/70/17)
Yours are 31.725, assuming you have 16's.
Aren't the stockers 265/70/17? Can't for the life of me remember.
If I select a different vehicle under vehicle selection will it delete all my saved tunes on the current vehicle? I know you've discussed that before.
Reason I'm asking, at first I have chosen a different vehicle not under v2betta but just regular one, make and model of my truck, I was still using old software for few days . Now trying to save names on beta software and it says that name already exists, I'm guessing from old tune on other software so I want to choose a different vehicle and delete Tunes I made there
Is this for canbus only? and adjusted on level 3
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
17 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
lvl 0 stock
lvl1 = power reduction mode
lvl2 = 0-10 psi of what you posted
lvl3 = 0-30 psi of what you  posted
lvl4 += 0-30 of what you posted plus wiretap.
16 minutes ago, Me78569 said:
lvl 0 stock
So is it yes then, on level 3 from what I posted using that chart I'm only using canbus fueling? and level 4 and up wire tap comes in, but it's not using same table as can bus above but adds to it through TPS Pump MAX and NIN settings and the Fuel Strech?  Then where does Pump Low Boost Limit % and Pump Low Boost Scale PSI come in, at given PSI of Boost? Lets say Tune I'm using it's set at 8% is this 8 PSI? so when I get to 8 psi of boost, if I'm on level 4 or higher that's when Pump wire tap kicks in? And if I'm on level 3 then Pump stretch never comes on? Sorry, but I think I'm getting really close on figuring this out. Will be taking programming classes soon :)
lvl 3 only uses canbus tuning.
lvl 4 will use wiretap starting at the psi you have configured HOWEVER if your Low Limit % is set above 0 you will get that % of wiretap before the low limit psi is reached.
So your example of 8 psi %8
From 0-8 psi you will get %8 of wiretap,
8-11 psi you will get 33% of %100 - %8 = 92 /3 or ~38% wiretap ( %30 = orginal %8 )
11-14 psi you will get anotheer 31 % so 38 + 31 = 69 %
14- 17 psi you will get the last 31 %
So if Pump Low Boost Limit % is set to 0, then when does wire tap comes in by default at what point of psi or tps ? :doh: and 8-11, 11-14, 14-17 math you're using, is it something also set by default?
If it is set to 0% then you get no wiretap until your low limit psi is reached.  Think of the low limit psi as the point where wiretap comes on as normal, think of the % as being how much wiretap you want before normal wiretap is reached.
The math I was using is just how the smoothing feature is configured i the code.  Nothing you can change there, I was just showing you how wiretap ramps up once you hit that low limt.  We can't just say "hey we are at xpsi let fuel rip"  I would...and does:burnout:cause the backend to let loose.
  "If it is set to 0% then you get no wiretap until your low limit psi is reached."
Low limit PSI = TPS Pump Minimum?
I think I got it and no I'm not messing with you :), too much going on at once trying to concentrate on something complex isn't easy.
I've read and reread this Quadzilla Custom tuning In depth but noticed that names and terms used are slightly different and it's making me second guess myself, like under  Wiretap Tuning it says  (Low Boost Pump Scaling: 0-100%) phone app says Pump Low Boost Limit%  and  (Low Boost Limit Pump: 0-25 psi) phone app says Pump Low Boost Schale PSI :ahhh:
Also  Timing Reduction Max says (The range for this reduction is 0-10*) but on the app it's 5*
So you can see where it's a bit confusing for someone that just trying to figure it out. I hate to ask a million questions, but if I'm not 100% sure what I'm adjusting then none of it will work right. Not sure if there is a way to have instructions mach the names to be identical to whats on the phone app or vice versa. Not a complaint just a suggestion. I'm sure there are people out there dumber than me and wondering same thing, maybe not.
Its on my list of stuff to get to.  I need to make sure the words match and the % match the final configuration.
LOW limit Psi is not the same at TPS pump min. TPS pump min is to prevent wiretap when throttle is below that %.  Psi low limit is purely based on boost.
Thank you Nick I had a felling something was a bit off. I realize that this is all new and it takes time to get it where it needs to be.
Would you guys think this be a good tune for MPG with 60hp injectors
Fuel Load timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Pump Stretch:1200
TPS Pump max:100
TPS Pump Min:25
Boost Scaling:40
RPM Limit:3200
Power Reduction:
0 PSI %:96
1 PSI %:96
2 PSI %:97
3 PSI %:98
4 PSI %:99
5 PSI %:100
6 PSI %:101
7 PSI %:102
8 PSI %:104
9 PSI %:106
10 PSI %:108
11 PSI %:110
12 PSI %:112
13 PSI %:114
14 PSI %:116
15 PSI %:118
16 PSI %:120
17 PSI %:122
18 PSI %:124
20 PSI %:126
22 PSI %:128
24 PSI %:130
26 PSI %:130
28 PSI %:130
30 PSI %:130
Edited by Me78569
Quote
Fuel Load timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Pump Stretch:1400
TPS Pump max:100
TPS Pump Min:25
Boost Scaling:40
RPM Limit:3200
Power Reduction:
0 PSI %:96 ** you might bump this by a few % depending on how cleaner your injectors are
1 PSI %:96 **
2 PSI %:97 **
3 PSI %:98 **
4 PSI %:99 **
5 PSI %:100 **
6 PSI %:101 **
7 PSI %:102 **
8 PSI %:104
9 PSI %:106
10 PSI %:108
11 PSI %:110
12 PSI %:112
13 PSI %:114
14 PSI %:116
15 PSI %:118
16 PSI %:120
17 PSI %:122
18 PSI %:124
20 PSI %:126
22 PSI %:128
24 PSI %:130
26 PSI %:130
28 PSI %:130
30 PSI %:130
Edited by Me78569
I know this aint mcdonalds but I'm loving it. :cheerleader:
Ok I just tried this tune below for MPG and truck seems ok with it, no hase at all on take off, accelerates ok given these parameters, reason I didn't put anything for  Pump Low Boost Limit: and  Pump Low Boost Scale %  and TPS Pump Min:25  is I don't want wire tap at all for my mpg tune. Plus I leave it on levl 3 just to be sure. Truck is empty with topper on going about 55-60 and now i lowered PSI% down quiet a bit and it's not that much different other than can bus is a tad lower. I was switching between my DD tune and MPG tune just to see the difference at steady speed and it didn't seem to change much other then egts a little and canbus fuel in data logging was higher with DD tune. So not sure where I'm heading yet but truck is definitely smoke free and smooth. I might reduce timing a little just because I'm using less fuel. How does Timing Limit work VS Cruise Timing Advance?
Fuel Load timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Pump Stretch:1200
TPS Pump max:100
TPS Pump Min:25
Boost Scaling:40
RPM Limit:3200
Power Reduction:10
0 PSI %:90
1 PSI %:91
2 PSI %:92
3 PSI %:93
4 PSI %:94
5 PSI %:95
6 PSI %:97
7 PSI %:98
8 PSI %:99
9 PSI %:100
10 PSI %:101
11 PSI %:103
12 PSI %:104
13 PSI %:105
14 PSI %:106
15 PSI %:108
16 PSI %:109
18 PSI %:112
20 PSI %:114
22 PSI %:117
24 PSI %:120
26 PSI %:123
28 PSI %:126
30 PSI %:129
Just noticed there is no 17PSI%
Edited by Me78569
It will take 10 - 15 seconds for the tune to fully apply when you switch it on the fly.  No issues doing so just keep that in mind.
I doubt honestly you would notice much difference because the truck requires x HP to keep moving at a given speed.  Changing the tune prob won't change much within reason.
Timing Limit is really taking into account when you are on the gas pedal, at low boost it really doesn't do much and at cruise it is actually ignored.  Cruise timing is ONLY used when MPH and TPS are stable and above ~35 mpg.
Ok the amswer is no, I went to previous vehicle I had selected and deleted all tunes and then went back to v2betta and everything was still there, and yes I couldn't create a tune that had a same name on different vehicle selection
We need an update to the Iquad app, to allow copying profiles and deleting / renaming them.
Neither android nor apple products have that ability. That would be up to @Quadzilla Power power to decide if they want to develop that.
Did This Forum Post Help You?
