I feel that it is time to start building a list of tunes that we all use.
Please learn what each tuning variable does.  There V2 tuning article covers everything in depth along with a video explaining each item.
This tool will allow you to edit Quadzilla tunes from your PC.
Update 1/15/17 V2.2 tunes should include timing maxes for various RPM's and fuel load timing
Copy this into your post and fill out the info
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Light Throttle Timing Load Limit:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Minimum Pump Tap Fueling Percentage:
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
7 x.009 DFI injectors, he351ve arduino controller
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Light Throttle Timing Load Limit: 30
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Minimum Pump Tap Fueling Percentage:0
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Minimum Pump Tap Fueling Percentage:15
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Minimum Pump Tap Fueling Percentage:10
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
@Carbur8tr For your towing tune.
lvl's I like 6 because I don't like having to push the plus button 1000 times.  but you can set this to whatever you like
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 274.5k
  • Quadzilla Power
    Quadzilla Power
    Not at this point. We are working on something that will enable measureing those as well but we don't have them in production yet. It will be some time.  -thanks again,
  • yep, most complain coming to V2 tuning because they are used to the butt dyno telling them "WOW I just touch the throttle and it jumps out of it's own skin"       what people don't consider
On ‎11‎/‎11‎/‎2016 at 8:57 PM, TFaoro said:
Neither android nor apple products have that ability. That would be up to @Quadzilla Power power to decide if they want to develop that.
I agree, but since they listen to this forum I just wanted to put it out there. I thought @Me78569 was working on the code for the APP? I wonder if this is something he can pose to quad to incorporate. Also Custom warning thresholds for the gauges would be awesome.
These features have been requested to them already.   Not sure if they will make the cut.
I'm a little new to diesel tuning, and I copied @Me78569's DD tune for a baseline with my 7x.010 SAC injectors which is working great so far, but I have a S366 / HX35 compound setup coming, and I was wondering what would be a good baseline with the better turbos.
That all depends on YOU haha. Start out with your current tune and increase as you see fit while remaining smoke free or at a light haze. If you have a light foot you can ramp up faster. If you have a lead foot you'll have to ramp up slower. Your spool will likely remain close to the same as just the HX.
What do you think about timing? will timing help spool the turbo? Or just fuel?
So... in theory lower timing helps spool turbos faster. This is still in the test phase for 2nd gens though, so no guarantee on whether it will work well for you or not. You could increase your Low Psi Timing Reduct and possibly see faster spool. Like I said earlier though, you likely won't see see a benefit because your spool should be the same as the hx. Once the HX lights, it'll help get the 66 moving.
Did a little tweaking of my tow tune
Quote
Power Levels: 6
Fuel Load timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Pump Stretch:1200
TPS Pump max:100
TPS Pump Min:20
Boost Scaling:40
RPM Limit:3200
Power Reduction:15
0 PSI %:88
1 PSI %:90
2 PSI %:92
3 PSI %:92
4 PSI %:93
5 PSI %:94
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:100
11 PSI %:102
12 PSI %:104
13 PSI %:106
14 PSI %:110
15 PSI %:114
16 PSI %:118
17 PSI %:122
18 PSI %:123
20 PSI %:124
22 PSI %:125
24 PSI %:126
26 PSI %:127
28 PSI %:128
30 PSI %:130
I just leave it turned up, cruise state I don't have any wiretap, then a touch of throttle and I am in the 15-20 psi range.
Great off idle power, with a touch of haze.
Edited by Me78569
I drove it.  The tuner does a good job.
@CSM
The tune is a bit different than the one you drove with.  much more off idle meat.
I blew the tires off the truck with a trailer hooked up leaving a stop sign haha.... Thankfully the trailer was empty.  Haha hard getting used to the change.
Edited by Me78569
17 minutes ago, Me78569 said:
@CSM
Dana 70s are tough...
22 minutes ago, Me78569 said:
@CSM
I've already got that problem with the Jayco RV hitch up and loaded.
Says the guy with a New Dana 80 hahaha
Edited by Me78569
I have been spending some more time tuning.  I now have a more aggressive DD tune,  I only get haze, which is more than before but still only haze..  The perk of the new tune is a good bit more offline go.    I am still sure I could pass emissions with this tune.
Quote
Power Levels: 6
Fuel Load timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Pump Stretch: 1750
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3400
Power Reduction: 15
0 PSI %: 88
1 PSI %: 89
2 PSI %: 90
3 PSI %: 91
4 PSI %: 92
5 PSI %: 93
6 PSI %: 94
7 PSI %: 95
8 PSI %: 96
9 PSI %: 97
10 PSI %: 98
11 PSI %: 99
12 PSI %: 100
13 PSI %: 104
14 PSI %: 108
15 PSI %: 112
16 PSI %: 116
17 PSI %: 120
18 PSI %: 124
20 PSI %: 128
22 PSI %: 132
24 PSI %: 136
26 PSI %: 140
28 PSI %: 140
30 PSI %: 140
Edited by Me78569
Currently Running this tune, with good results, but thinking about comparing this DD tune to the one @Me78569 just posted. I get a light haze from mine heavy on the throttle, and just a smidge of black smoke during hard shifts.
# Power Levels 6
Timing Limit 15
Timing Scale 54%
Low PSI Timing Reduct 2.5
Timing Reduct Scaling 100%
Cruise Timing Adv. 3.5
Max Fuel Stretch 1700
TPS Pump MAX 100%
TPS Pump MIN 25%
Pump Low Boost Limit % 5%
Pump Low Boost Scale PSI 10
Boost Scaling 40 PSI
RPM Limit 3200
Power Reduction 15%
0 PSI 85%
1 PSI 87%
2 PSI 89%
3 PSI 90%
4 PSI 92%
5 PSI 93%
6 PSI 94%
7 PSI 95%
8 PSI 95%
9 PSI 96%
10 PSI 97%
11 PSI 98%
12 PSI 100%
13 PSI 104%
14 PSI 108%
15 PSI 112%
16 PSI 116%
18 PSI 120%
20 PSI 124%
22 PSI 128%
24 PSI 132%
26 PSI 136%
28 PSI 138%
30 PSI+ 138%
I am going to try your tune out with the 7x.010 SAC, I will log a couple trips and let you know how it works, I like the fuel curve on that one
Also, you have 17 PSI listed, my Quad jumps from 16-18-20. is that an issue?
Edited by xxTJRocksxx
table formatting
Here is my current empty truck tune for +50HP injectors. Just a light gray haze for WOT runs. I'm using my exponential curve now. Starting at 100, with a growth of 1.3%
http://www.rapidtables.com/calc/math/exponential-growth-calculator.htm
Power Levels: 7
Fuel Load timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Pump Stretch: 1400
TPS Pump max: 100
TPS Pump Min 5
Pump Low Boost Scale PSI: 10
Boost Scaling: 40 PSI
RPM Limit: 3200
Power Reduction: 5%
0 PSI %: 100
1 PSI %: 101
2 PSI %: 102
3 PSI %: 103
4 PSI %: 105
5 PSI %: 106
6 PSI %: 108
7 PSI %: 109
8 PSI %: 110
9 PSI %: 112
10 PSI %: 113
11 PSI %: 115
12 PSI %: 116
13 PSI %: 118
14 PSI %: 119
15 PSI %: 121
16 PSI %: 122
18 PSI %: 126
20 PSI %: 129
22 PSI %: 132
24 PSI %: 136
26 PSI %: 139
28 PSI %: 143
30 PSI %: 147
Edited by Me78569
No issue, My mistake in the tune I have listed it jumps by 2 psi from 16 and above.
I am liking this tune A lot, not really any smoke normal driving conditions, and the off the line is pretty healthy.
New Performance Tune...
+50 HP injectors, HX35W Turbo, BHAF, and 3" Exhaust.
It still smoke-free. Pulls like a crazed mule. 3rd gear on dry pavement it will spin the tire just rolling into the throttle. MPG's are down about 2-3 MPG but the power is much greater. It stupid powerful out in the snow really have to watch your throttle foot closely it takes very little throttle to get all 4 tires (4WD) to light up even on wet pavement now. No problems with EGT's either very cool running.
Power Levels: 7
Fuel Load timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Pump Stretch: 2000 microseconds
TPS Pump max: 100%
TPS Pump Min: 20%
RPM Limit: 3400
Power Reduction: 10%
0 PSI %: 105%
1 PSI %: 106%
2 PSI %: 107%
3 PSI %: 109%
4 PSI %: 111%
5 PSI %: 112%
6 PSI %: 114%
7 PSI %: 115%
8 PSI %: 117%
9 PSI %: 118%
10 PSI %: 120%
11 PSI %: 122%
12 PSI %: 124%
13 PSI %: 125%
14 PSI %: 127%
15 PSI %: 129%
16 PSI %: 131%
18 PSI %: 138%
20 PSI %: 138%
22 PSI %: 142%
24 PSI %: 142%
26 PSI %: 150%
28 PSI %: 150%
30 PSI %: 150%
Edited by Me78569
Hey Guys, I have been experimenting with so many tunes that I started a library and gave them their own "Codes" so I can keep track. Please see the Pictures Below, I am having good luck with Test Tune 1 / XA2 and Test Tune 2 / XM2.
Regarding Timing, I am finding that my truck seems to like 12* @ 80% Scaling.
Tune XM2 / MPG 2 Has good power down low, but leans out just enough on the highway for 31MPG @ 70 MPH on the instant disp. This is not a power tune, its not fast and on PL3 I can barely make 30 PSI with my compounds.
I have attached the Curve graph for you to see how aggressive they are.
I am running S366/HX35 Compounds and 7X0.010 SAC Injectors, on XM2 I barley get a haze with the pedal on the floor.
@xxTJRocksxx
Give me Videos or give me death!!!!
Please :whistle:
Did This Forum Post Help You?
