I feel that it is time to start building a list of tunes that we all use.
Please learn what each tuning variable does.  There V2 tuning article covers everything in depth along with a video explaining each item.
This tool will allow you to edit Quadzilla tunes from your PC.
Update 1/15/17 V2.2 tunes should include timing maxes for various RPM's and fuel load timing
Copy this into your post and fill out the info
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Light Throttle Timing Load Limit:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Minimum Pump Tap Fueling Percentage:
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
7 x.009 DFI injectors, he351ve arduino controller
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Light Throttle Timing Load Limit: 30
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Minimum Pump Tap Fueling Percentage:0
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Minimum Pump Tap Fueling Percentage:15
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Minimum Pump Tap Fueling Percentage:10
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
@Carbur8tr For your towing tune.
lvl's I like 6 because I don't like having to push the plus button 1000 times.  but you can set this to whatever you like
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 278.6k
  • Quadzilla Power
    Quadzilla Power
    Not at this point. We are working on something that will enable measureing those as well but we don't have them in production yet. It will be some time.  -thanks again,
  • yep, most complain coming to V2 tuning because they are used to the butt dyno telling them "WOW I just touch the throttle and it jumps out of it's own skin"       what people don't consider
19 hours ago, Me78569 said:
Use valet mode power to find your starting point.  set the Quad to lvl 1, then set valet mode power at 75%.  From a stop stomp on it.
Ok, @Dieselfuture i put that tune in, its a little bit better.  The truck idles very smooth in park and neutral, but AS SOON as i put it in gear, i fight a VERY heavy lope.  Im sure its dumping too much fuel and choking itself out.  It has stalled a few times waiting at lights.
Also, driving around town in 3rd gear at about 1800-2000rpms, im about 900degrees. Seems a bit high to me, but since this is my first diesel and build, im a bit uneducated.  I may have forgot to mention that i have the hardfuel tune rather than the standardfuel.
As for the valet tune @Me78569, are u saying to use the default tune and start there?  I appreciate the help gents!
No in your custom tuning menu create a tune, in that tune you will see "valet mode power"
that setting applies to lvl 1 of the Quadzilla and it allows you to set fueling between 0% and %100 of OEM.
So what you need to do is figure out your starting %.  So go out set valet mode to %80 and stomp on it with the Quadzilla set to lvl 1.
Is it smokey still?   If so drop the Valet mode power by 5% and try again, is it slow, then up the valet mode power by %1.
Do this until you find a good spot for your tune to start.  Once are happy with how the truck takes off and smoke levels then you will start your canbus tuning at that %.
Until you know your Start % you can't do much.  You will just be blindly guessing.
As for lope the quad is not adjusting fueling at idle, that is a result of your fueling setup.  The Quadzilla will not change idle state behavor.
@Me78569 ok, thanks for kinda dumbing it down for me a bit more. Lol. I feel like an idiot for being so lost with tuning, but ive never tuned before with anything other than a 4 barrel carb and flathead screwdriver lol.
Ill see what i can get started and report back in a day or two.
with your injectors I would expect you to be happy with valet mode at %75-%85 of oem fuel.
start playing with it and it will start to make sense, there is nothing complex about it, it's just a lot to understand at once.
I've got a similar issue, not a heavy lope but there is a lope as soon as I start to launch out of 2nd gear.
Ok.  Yea my lope is pretty intense...like i said, idles smooth in park and neutral, as soon as i go to reverse or any forward gears, and hold the brake, its loping hard, so hard that it starts to stumble and will eventually stall...ill see if i can get a video of it tonight
Being I'm a manual it lopes as the clutch starts to engage. I'm smaller on the injectors at 7x0.0085 (+75 HP). Then as I coast up to a stop with the transmission in neutral it lopes dropping the RPM's to like 700 RPM and bounce up to roughly 850 or so. Once I come to stop it idles right at 800 RPM's.
Maybe try running standard fuel and not hard, I haven't messed with hard fuel at all so I can't help there.
Ok, so i just spent about an hour and a half out on back roads and this is what ive come up with.  I started at 75% on the valet mode.  On the lower end below id say 15psi its a tad smokey, but as i get higher in boost and really get after it, the smoke lightens up.  Its not a haze, but its not black either, right in the middle.  The truck pulls like a dragster, BUT im still experiencing very high EGTs...quadzilla picked up 1600+ degrees.  Id love to see it not climb over 1400...what changes do u guys see here that would drop those EGTs?
Also i took ur advice and dropped the timing a couple degrees and it took away the popping in high rpms...
Power Levels:  6
Timing
Fuel Load Timing: 2
Light Throttle Timing Adv: 2
Timing vs rpm
1500: 15
2000: 17
2500: 19
3000: 21
Timing Max: 23
Wiretap
Pump Stretch: 1800
TPS Pump max: 100%
TPS Pump Min:  20%
Minimum Pump Tap Fueling Percentage: 0
Pump Low Boost Scale PSI: 12
Boost Scaling: 38
RPM Limit: 3400
Power Reduction: 50%
0 PSI %: 75
1 PSI %: 76
2 PSI %: 77
3 PSI %: 78
4 PSI %: 79
5 PSI %: 80
6 PSI %: 81
7 PSI %: 82
8 PSI %: 83
9 PSI %: 84
10 PSI %: 86
11 PSI %: 88
12 PSI %: 90
13 PSI %: 92
14 PSI %: 94
15 PSI %: 96
16 PSI %: 98
18 PSI %: 102
20 PSI %: 106
22 PSI %: 110
24 PSI %: 114
26 PSI %: 118
28 PSI %: 122
30 PSI %: 126
Edited by Me78569
Zippo difference between the two tunes until 3200 rpm.
Lope is not related to the quadzilla as it does it without to input.
So, a swing and a miss on this tune?
And i thought i made progress :doh:
I guess where im getting the most confused is when i start messing with the wiretap and stuff...and basically everything with the timing.  I think its because im so green when it comes to what advancing or retarding the timing actually does.  For some reason im just having problems wrapping my head around it.
Edited by TJ_00Cummins
Sorry I was talking to diesel future not you, hardfuel and standard fuel base tunes are the same below 3200 rpm, you are messing with the custom tuning on top of the base tune. You made great progress.  Good job for going out and doing that!
Your canbus tuning looks good. Turn your wiretap down to 1400 and report back.  You have a ton of mechanical fuel so you don't need much wiretap to make good power.
Your timing curve looks ok.  I know big injector trucks can't run as much timing so you might be a ok.  Might bump 2k+ by 1* and see how it runs.  I would expect Max timing for you to be 24*-25*
Again kiddos for jumping in.
Edited by Me78569
Oh ok good deal! I was a bit dicouraged because i was wondering where u were getting 3200 rpms from...i was lost haha.  But yea, i will turn the wire tap down and try her tomo.  I had thought about changing it but decided not to.  Ill report back tomo! Thanks for the tips and guidance! And patience!
No worries you'll get it.
Hardfuel tune just tries to extend canbus fueling to 3500 rpm the Standard fuel tune doesn't.  That's the only difference I was speaking of.
 Don't be discouraged, you'll get it.  Let us know how it goes.  Bumping timing in the 2k+ region will also help egts.  Increase in 1* increments until you get surging then pull back by .5* until happy.
Yea I will keep my nose to the grindstone.  I love learning new platforms and learning how everything meshes tofether to create the most efficient power possible.
When u say to adjust the time 1* at 2k+, is this what youre meaning?
Timing vs rpm
1500: 15
2000: 17 to 18
2500: 19 to 20
3000: 21 to 22
Max timing:23 to 24
@Me78569 didnt have much time to tune today, i changed timing though...i also think im going to pull some fuel, its smoking more than i initially thought...not super bad, but id like to lean it out just a little bit. And i may change the wiretap from 12psi to 10.
Thoughts?
Thoughts?
I would bump the timing a touch more. Go a couple degrees up and run it on level 3. If / when it starts to surge, then back it back down.
I though your starting point would be a touch high with those injectors. FWIW mine started at 69% with 7x.013's.
Do you have a box 66 or is it something else?
Yea, i thought about taking all the CANBUS down a touch.
 Forgive my lack of knowledge, but whats a box 66? Lol
What turbo specifically do you have?
How did the changes do?
