How do I manually install The Quadzilla Driver / Load the Quadzilla V2 tune on Windows 10 / 8 / 7
  • Replies 85
  • Views 59.4k
  • I just want to say thank you. This was a long process for me to get this updated as I’m totally lost when it comes to using a computer but there has been a lot of time and effort into setting this up
  • What you do????     Also at this point I am fairly confiedent that you won't need to flash another tune in the near future, unless someone finds something big.  I have been driving on this f
  • I pinned this as I feel like it will help a lot of people see it.  As I said above Please print out the PDF or use another computer so you can follow the steps.     The process does work if
Hello! This may be a stupid question but I just purchased my Quad at the end of December 2018. Everything seems to be running fine. Do I need to update mine?It says V2.7.  Its the iOS WiFi version.
In the datalog do you have a date in the build date field at the bottom?
If yes,  you dont need to do anything
If no, do you want v2?
If yes, you need to flash
If no, you dont need to flash
Ok thanks! I will check when I get back to my truck.
Looks like I’m good to go with the Newest update. Thanks ME!
trying to flash an XZT, i followed the video for windows 7 using the 32 bit installer. i click the tune file to download from the desktop after plugging in the box, i then click ''get information from module'' but i keep getting a popup box saying retry or cancel, even after multiple retry attempts. unplugging and plugging in, even downloading the tune again and still the same thing. any idea? ive also tried 3 different cords that all say data transfer so those are good too.
