Shuddering at the 18s
CTcummins24V you might have nudged Mr in the right direction.  I replaced the accelerator position sensor because I hadn't replaced that yet.
Then I noticed there was a way I could move alternator wires to give a couple more inches of clearance and after a test drive I didn't feel the problem.
Tomorrow I'll drag the trailer around since it's far more noticable with more drag and I'll know for sure.
Well damn.  That wasn't it either.  Now I'm considering an injector problem.  I did see a post about a cracked/sticky injector causing shuddering, more noticeable after trans lockup.
So, on Monday, I'm pulling the injectors and sending them to DDP for testing.
Well....  Before puling the injectors...
What about the harmonic balancer/damper?  I didn't realize that part is something of a consumable part in the 1999 year.  I understand later they went to a fluid filled damper but in my year they were still using two plates with a rubber separator and the rubber eventually breaks down.
I was reading that the stock damper is designed to damp what the engineers considered predictable vibrations.  But, as we add power, we change the vibrations and can make them more severe.  There are fluid dampers available now, for like $400.
Any thoughts?
FIXED!  I have been chasing this problem for a frigging year!
Five mechanics in five different shops and NONE OF THEM looked in this direction.
There's still a slight shudder around 1800 that maybe the fluidampr can't cope with or, hopefullly not, the bearings have worn from a year of vibration.
MUCH easier to spin up, power is much more accessible.
Man that's hard to believe, update us in few months to make sure, other than that hope it's what it is. Wired things do happen.
I'm now almost wondering if something internal isn't screwed up and fluid damper is compensating for it, and that is why you still have a slight problem.
You're right, I'm hoping the damper isn't helping to hide a different issue.  This did show up after the cam, sittings, rods and studs were added and the rods at least would change the reciprocating mass.
But, we'll see where I am in a month.
I already tossed the old damper.  The drive shaft has already been re-balanced and all the U joints replaced.
The new dampener did smooth it out but I can feel the problem still.  one thought is a cracked injector that's leaking when it's under heavy load.
What else were you considering I look at?  The diff looks fine inside, visually, but I'm open to external wisdom.  It does have the limited slip diff.
Edited by OverToyed
