10 hours ago, Alexio Auditore said:
How long have some of you been running mechanical? Any issues?
   I installed mine just over 4 years ago (5/2013) .  Fuel pressure was 17 at idle and 19 going down the road when first installed then went to near 0 a few days later.  I found a bit of debris from the installation keeping the fuel pressure regulator stuck open.  It's e-z to open the regulator and clean out or adjust fuel pressure if there is a need for it.
    I keep a spare belt under the back seat but there is also that spare fuel pump in the fuel system.  All I need to do is in stall the fuse.
12 hours ago, Alexio Auditore said:
Are there anythings to be worried about going the mechanical way? How long have some of you been running mechanical? Any issues?
 4-5 years, on 25k miles. Downside is no extra filtration other than the stock fuel filter and will only work with oem harmonic damper, no aftermarket viscous damper.
This is what comes in a Fuel Boss installation kit.  The hose is 3/8 or up grade it to 1/2 and you can add a draw straw or use the stock pickup.  For my needs I stayed with the 3/8 hose and stock pickup.  If I was to opt for more power like bigger injectors and such then I'd install 1/2 line with a straw.
http://www.glacierdieselpower.com/product.aspx?pf_id=FB-98502
A shop here in CDA I believe makes a separate unit for the filter and water separator, it's like what the fass looks like but without the pump, so that could be a option also, I'd have to double check just to be sure((( I could be totally wrong to, wouldn't surprise me))))
I am cheap and do not spend more than needed. I installed a raptor 100 on the frame with a push on 3/8 screen (P550749) Vulcan. NO new drop tube.  Bought a tapped (tab) banjo for the pressure gauge which is manual and 3 push lok banjos (B1206) from Vulcan. I drilled all banjos out to size of the tapped banjo. Ran 3/8 hose clamp line all the way to the pump. The pressure gauge is a 30 psi oil filled mounted through the floor on the transmission hump fed by 1/4 in nylon tubing. This set up is a 294% improvement from stock. I set my pump to 18psi at idle. I have  13psi at full throttle on a 6% grade pulling 18,000 gvwc.  I change my fuel filter at 20,000. Spend more if you like, but this worked for me. PS , Stay away from QD fittings. QD's are not made for suction.
