11 minutes ago, 01cummins6 said:
In that location could it also be thermostat housing leaking
Take some pictures and post them up so we can help you diagnose :thumbup2:
The circled area is the leak right above is where the head aND block come together.
18 hours ago, jlbayes said:
My head gasket literally blew right below the tstat housing......
Did you have any coolant mixing with or anything
That picture could be of an alien autopsy:think:.  I can't figure out what you're taking a picture of.  Sorry, I'm no help.
This is the front part of my head gasket when I redid mine, wasn't leaking or anything but after 348,000 miles I figured it was time to replace it. It was literally falling apart and I have no idea what that sand like substance on the top right was, but It's a good thing I replaced it. Probably the same thing for you, failing at the coolant passage port.
Yes it did. However I know of others that did not. Pressure tester on the rad will show you.
