well gentlemen you guys say use the parts lookup but I cant find it useful so if anyone knows where I can find a 47re solenoid or whatever and pretty much service my transmission thanks ahead
  • Replies 16
  • Views 6.3k
  • Mopar1973Man
    Being it's an automatic you might look for the BD noise filter on the PCM and remove it. Then have the alternator tested. I've seen so many trucks with AC noise issues that lose injection pumps and EC
the shift solenoid is what I was told but I would love to service my transmission, ever so often it seems like it wants to take off in second for a bit
I bought truck at 239200 miles it has 241500 and I got ahold of old owner and they said it was rebuild with 30k warranty but idk how well that holds up, it just sucks I have payments on this thing and already put a new injection pump and what else pretty much bought someone lemon ! anyhow yea I could use a transmission tech
Being it's an automatic you might look for the BD noise filter on the PCM and remove it. Then have the alternator tested. I've seen so many trucks with AC noise issues that lose injection pumps and ECM because someone installed a noise filter and modified grounds.
well I do believe the alternators good I did all that testing when my injection pump went out lmao all it was a bad in inj pump but I bought a new alt because the test said its volts was high and oriellys said it was good but they sold me a new one anyway haha
, idk man I would love to take it to a shop but any regular shop would screw me so I need to take It to cummins tech or so forth with 47re
@ItzReckless it's a pretty easy job putting in new solenoid  & transducer.  Just a little messy if you don't have a drain on tranny pan.  I did mine a few months ago.  Cascade has the best price on the solenoid i could find.  Get the borg warner solenoid.
L8tr
D
I ended up getting a whole kit all I used was the 2 solenoids and I'm saving the sensor idk what the other stuff is for if anyone knows , also it fixed the takeoff part ! thanks labor was very easy and I didn't spill a drop
hey someone linked the npt fittings to replace my trans lines but they are the ones for the tranny to the front of truck I need a size on the on from the heat exchanger to the front of truck
