So I just finished dropping an 01 engine in a 98.5 truck, dealt with the cmp signal error. But now my abs light won't go out. No abs related codes, no CELs and I can't get the ABS, motor to actuate via the scanner (modus from snap on). What am I missing?
01 engine, 01 ecm, 98.5 harness with 01 pcm (manual transmission) 01 MAP sensor, custom extension harness for the crank sensor to relocate to the timing case (yes I have to correct reluctor wheel on the cam). All three rpm data sources read nominally the same. CCD buss checks out, I couldn't get the ABS module to activate via scanner, I swapped in the 98.5 ecm and ABS light is still on with no codes and still won't trigger with scan tool.
2 hours ago, syndicateshop said:
Well turns out the powersteering fluid was low, abs light went out after bleeding the powersteering.
Might have to try this tomorrow and see if it turns mine out. I have had no signs of it being low.
