Wont crank just clicks
- Replies 11
- Views 8.6k
kzimmer 3 posts
jsmyer 3 posts
Chris O. 1 post
DieselJunkie 1 post
Just need a little help. Have an 02 Ram 3500 wont crank until it is placed on a battery charger with a start circuit or left on charge over night. I have replaced the batteries twice, left and right battery cables have been replaced, starter has been replaced, checked fuses and the relay they're all good, cleaned all ground connections put dielectric grease on them. At a serious loss on this. Starts fine if its been sitting on the charger overnight. Some days doesn't need the charger some it does. Have put a meter on the starter and when when the key is turned over there is no draw at the starter or batteries. batteries are both 12.7, 12.8. Any help would be appreciated.
