I think I remembered about certain things you when adjusting steering play. Don't bear down hard on the adjustment screw, turn wheel back and forth making very small adjustments each time, raise the front off the ground....... That sort of thing?
Thanks for any advice.
BTW, My truck knows the way toIMG_0914.JPG.f952e27eb97d46954e1681c688b7df54.JPG these kinds of places
  • Replies 10
  • Views 3.5k
  • Mopar1973Man
    You'll be surprised I've seen some boxes where I turn 3 to 4 turn just to find bottom again. Then loosen 1.5 turns. That means if you doing 1/8 turns that would be 12 times of adjusting and test drivi
  • I guess I have to base mine on my past experience with a S-10 Chevy. Cranked way down on it and it turned like a dream in the parking lot. Jumped it out on the road and when I went for second the truc
  • For anyone reading this in the future, my truck (likely stock steering gear) required a 3/16" hex key and 5/8" wrench.   Either a stubby or ratchet-wrench would've made this project super ea
All I have ever done is tighten it up. No lifting, jacking, steering nothing. First time I only did 1/8 of a turn and had to do it twice to get results. This last time I did a 1/4 turn and need to do it again. I guess with 422k on it small adjustments dont work anymore. If you overtighten it you wil know. The steering wont return.
 Pretty sure there is a much more involved way to do it. Read it somewhere on a thread here a while back. I have just never done it that way personally.
Typically all I do is loosen the lock nut run the sector adjustment all the way in till it seats. Double check your not seating against the lock nut. Once you hit bottom then loosen 1.5 turns then hold the adjustment with your Allen wrench then tighten the lock nut again. You are done. Much fast than turning a 1/8 turn, test drive, turn again 1/8 turn, test... Etc...
I gave up on the 1/8th turn a while. Tried the quarter turn this time. might have to give that up too.
You'll be surprised I've seen some boxes where I turn 3 to 4 turn just to find bottom again. Then loosen 1.5 turns. That means if you doing 1/8 turns that would be 12 times of adjusting and test driving. If your doing 1/4 turns that still 6 times of adjusting and test driving. Or my way and do it once.
I guess I have to base mine on my past experience with a S-10 Chevy. Cranked way down on it and it turned like a dream in the parking lot. Jumped it out on the road and when I went for second the truck went on with the left turn I started. Did a real nice 180 in the road. Just did not want to see that happen to anyone.Just for you @Mopar1973Man :nadkick:
love ya, mean it. Ahhhh ha haaaaa!
Hence why you loosen after hitting bottom. Kind of like doing band adjustments on 47RE transmission you torque to 72 inch/pounds and the loose a number of turns. Samee thing here bottom out the gear and loosen so to add slack back from bottom.
So you know its time to adjust the screw when everything else tight, but find yourself over compensating the wheel to keep her straight down the road
Dripley Thank you for the 180 warning I appreciate that.:thumb1:
:lol3:
Edited by JAG1
Well you could go the extra step and just rebuild the box and reseal everything. During your re-assembly process you'll be readjusting the sector adjustment again. Which you'll do it the same way I just stated. Just got to make sure to add the slack back in.
  • 4 years later...
Either a stubby or ratchet-wrench would've made this project super easy.
Edited by LorenS
I have never done this! Maybe I need to give it a try and see what happens.
