- Replies 14
- Views 4.8k
Mopar1973Man 6 posts
Marcus2000monster 3 posts
JAG1 2 posts
IBMobile 1 post
Popular Days
Check the grounds for the lights. The resistance in the ground connection may be to high, .
No. You need to take up the door trim the kick panel by the parking brake pedal needs to be removed. The ground is behind the plastic kick panel near the door. Dodge changed up the headli
Hi all!! My headlights are extremely dim in high and lows! If I didn’t have a light bar I would have already been in the ditch probably! Lol not quite that bad but they are definitely abnormally dim! What should I check test etc ? Thanks
