Fuel part questions....fix or throw away?
- Replies 10
- Views 2.1k
Mopar1973Man 3 posts
Dieselfuture 3 posts
015point9 2 posts
dripley 1 post
I have a few left over parts from the fuel tank area after a “mechanic fixed ” my fuel system. Maybe I should just throw the parts in the garbage? but then again maybe someday might come in handy for me or for somebody else.
Fuel module…
The straw was actually the thing creating tension to keep it expanded inside the tank. Vulcan Diesel tried to fix and drilled out basket. Didn’t work so well, so I bought a new one. I was going to install some springs to create tension.
***Question…How much tension do you think is good? Maybe 3 pounds, 5 pounds?
FASS drawstraw…
Where the plastic pipe slides onto the nipple inside of tank is sucking air. Mechanic used pliers on the nipple to tighten the nut. Now nipple is egg shaped, out of round.
***Question…How to fix or what type of glue to make nipple air tight again?
Fuel tank…
Mechanic then said he has to install a sump. Of course it leaked and hose hung down to close to road. I finally found a used tank and put it in.
***Question… Can I get some plastic and glue on a patch to cover the hole that was drilled out?
Any ideas or just throw parts out? I do know it take over $450.00 to replace what got messed up and hate to throw them away. And a good lesson to me about choosing a mechanic, maybe I should consider the money tuition?
Your thoughts....Thanks
Edited by 015point9
