1 minute ago, Me78569 said:
If you dont build your own charge pipe, or go cheap wih a 45* bend to adapt the stock to work.
Stainless diesel offers this http://www.stainlessdiesel.com/index.php?route=product/product&product_id=176  I used that for my VE swap.  DAP sells a silicon piece that you can use,
Or you can build your own.
I’m not a pro fabricator so I’ll prob buy that one. What else do I need to know?
Are you looking for a tow tune at 400-450 or a street tune at 400-450 and 350-375 for towing?
The reason I ask is the HE351CW is about a 350-375 rwhp turbo for towing at altitude and reasonable EGTs.
The VE turbine wheel is larger and a common mod to the CW. It will spool better, reduce drive pressure, flow more, and sound better too :-)
My dad has the VE turbine wheel in his CW on his 06. I have him running about a 350-375 rwhp tune and it does awesome. It's efficient, cool running, and doesn't have EGT issues until WOT above 6-7K feet in the summer.
Edited by AH64ID
Looking for 450 for playing and around 350 for a safe towin tune. I haven’t heard of the compressor wheel mod! I’ll have to look at that! Would that make a difference with injector size? Still go with 7x10s?
you will need a he351ve turbine wheel.  Then you will need to have someone machine the cw exhaust side out to fit the bigger wheel.
Sounds like it could get expensive! @AH64ID do you know what the cost for machining was? I have been searching and having a hard time finding a wheel. Any sugggestion for a source?
https://m.ebay.com/itm/NEW-Turbine-Wheel-for-Holset-HE351VE-Turbos-Dodge-Ram-Cummins-ISB-6-7L-Engine-/182127696383
That WhT I’m looking for?
http://www.cumminsforum.com/#/topics/2372346?page=1
Found this turbo on CF. Says it has a little play. Is that ok?
I really like the he351cw for what it is, but honestly once you go down this road with getting the cw enlarged etc, you might as well have just bought a new sxe turbo.
ve turbine = ~$150
Mill work = $100- $200 by the time you get it all done.
turbo = $250-500
rebuild kit for the turbo $60
Intercooler piping to make a 3rd gen turbo work on a 2nd gen $100
Front cover plug for wastegate = $40
Edited by Me78569
ve turbine = ~$150
turbo = $250-500
I would somewhat agree with that. What turbo would you go with?
I am also thinking that I may just do the 351 and not enlarge it...
did you see the link for the turbo?
How would the sxe/HE351 donwith my stock injectors if I waited until they went out to get the 7x0.10,s?
for a fun 400 hp and more than enough power to tow anything the 2nd gen can handle I think a stock he351cw is a good choice.
the cw would be fine with stock injectors and tuning the sxe not so much, that really needs more fuel.
I think I want to go with the he351.
What exactly would need machined? I would like to get a quote from my local machine shop.
