2000 to 2002 Steering upgrade
14 minutes ago, trreed said:
Is that 14.2 hand calculated or 14.2 from the overhead lie-o-meter?
Just spoke to him briefly and don't know how he calculates but do know he is talking about in town stop and go mileage, which 14 ain't bad for a 7k pound truck.
26 minutes ago, dripley said:
A worn VP will do it also, but I would suspect you would have some other signs of that happening.
Truck has been running a bit rough after a cold start.
Hand calculated. Lie o meter has been reading 14.7.
18 minutes ago, Tom Robarts said:
My lie-o-meter never goes that low, usually shows 28-29
I think your lie o meter is shucked up big time LOL.
Not neccasarily stop and go because I live in a rural town with a population of 1k people. Only 1 main street and never stop and go besides turns and stops...
Let me add I can get 19.5 mpg on the highway running 75 mph. Pu t me down to 55 with turns and slow down as tom3rd gear I am not far off from you. The 96 I had with the V 10 I was lucky to get 8 mpg in those circumstances.
@dripley You might be too drunk to read this but my plans got canceled and I home again lol...
9 hours ago, IBMobile said:
@dripley what size diff do you have?
I'm seeing about 18 freeway, 16 city and 10.5-13 towing two trailers 12-14 towing just 5er.
D 80 with 3:55 gears
19.5 freeway, 14 around town, 11.5 pulling the 5th wheel
Sorry fell asleep before I drank all the beer.
Hand calculated when it was stock on stock tires 215/85r16 and 3.55's DRW 4x4 auto on the highway at 65 I averaged 23.5 over a 500 mile trip.  100hp injectors, EJWA with hot unlock, and 255/85r16s I see 15-16 on the same trip but my odometer is uncorrected so the mileage is off 10%
Wow that's a huge drop for going 215 to 255, maybe my vp is still good all I need is some pizza cutters.
There is an adjustment on the top of the steering box. It is a threaded shaft with a jam not on it. Loosen the nut and tighten the shaft. You are not trying to bottom it out. Try a full turn and if it does not bottom out tighten the nut back up and drive it. Be careful. if you tighten to much the steering will not return on its own. If you feel the shaft bottom out back it off half a turn the test drive.If the steering does not return well back it off a little more. The first time I ever did this was on a S 10 I used to have. Whipped out of the driveway on the street and the truck kept turning so beware.
Which direction do you turn it?
