quad v2 wiretap settings
- Replies 30
- Views 6.1k
rogerash0 12 posts
Me78569 7 posts
Quadzilla Power 5 posts
Mopar1973Man 4 posts
All conditions must be met for wiretap to apply. The pump low boost scale defines what psi the wiretap map starts at. Ie an offset. The tps settings define where the 0-100% axis of the t
I dont remember honestly. haha making code changes is a long daw out process from the app side. Make a suggestion to Quadzilla for these things, they have been good at putting user req
The tune will reimport after quadzilla changes the profile name back to what it used to be. I dunno why they changed it, likely oversight. you can open the json with notepad or similar
After reviewing Nicks video on the quad v2 custom tuning functions, which really should be described in the app so I dont have to reference the video every time, he talks about TPS Pump Minimum and Pump Low Boost Scale PSI controlling when wiretap is applied.
I want wiretap to come on at 20% TPS. If I leave Pump Low Boost Scale PSI to 0, will wiretap be left off even when boost is 0psi or greater? ie. whatever setting is set, either boost or TPS %, wiretap wont be turned on until the highest parameter setting has been achieved?
A digital light on the dashboard of the app that shows when wiretap is coming on would be really cool. That would clear up any confusion.
Also, is the max canbus fuel 4095? Lately the largest numbers I have been seeing in my data logs have been around 2900.
Also, is there a reason why Nick doesnt set max pump stretch to 2200 in his extreme tunes? Thats the maximum allowed, but 2000 is the highest Ive seen him input.
