11 minutes ago, Mopar1973Man said:
@5Solas meet up with me in Ontario yesterday. Talking a bit of truck in the parking lot. He's a newbie to the diesel family. So after about an hour of talking shop. I asked if he wanted to take a ride in my beast? "Sure", he said. I played it very cool and drove nice and easy from the parking lot over to the on-ramp of the I84 interstate. Then I let it have it. Poor guy was rather shocked to see that stock looking truck hauling as I hit 75 MPH at the end of the on-ramp merging in.
My last little tweak where I'm tunning for summer fuel and my 2 cycle oil now. It got enough power to break tires loose easy now.
@Marcus2000monster you might want to focus that energy on the Quadzilla next... :whistle:
@5Solas Welcome to the family!
Mike I might just do that. But I have to figure out the funny idle issue first in case that requires expensive parts.
Just now, Mopar1973Man said:
Ok.
Does the idle seem normal cold and only idle weird when fully warmed up? Then does the idle change if you barely feed throttle and go away?
It’s sounds more like rattle than anything. Does not sound like when I had air in fuel issues. It still seems to rattle when cold and warm so I’m thinking I need to redo valve lash and go from there. I would say that it is more noticeable after it’s warm.
On a side note that boost elbow from DAP had a set screw in the end. What’s up with that? Is it an adjustment screw?
Good bet I would start there..
Seems wierd becuase I did the valves 2 months ago. Half tempted to have local mechanic do it this time. Iv done it 4 times now and haven’t got it perfect I don’t think  lol. :mad:
Here’s something wierd. I’m almost positive that since I replaced the map I have a lot more smoke! Definitely more than therebused to be I think but who knows?
Too many people get in a hurry and do weird things on valve lash adjustments. When you are setting the valve lash it should be done on a COLD engine. Now when the jam nut is loosened you want to tighten the set screw (Allen Wrench) till the screw is just touching  the feeler gauge. Then the feeler gauge should slide in and out with the slightest resistance. Here is the tough part the jam nut has to be tightened without moving you setting. This takes a bit of thinking to do. If the setting feels slight tight you'll be twisting the set screw slightly loosen as your tightening the jam nut. Reverse applies if the setting is a bit loose you can twist the set screw slightly tight as you tighten the jam nut. Typically I go back and forth several times till I'm happy.
Now the one time I was in a hurry I install the DAP injectors +75HP SAC's and while the valve cover was off I did a quick valve lash. Then grabbed my torque wrench and set it for 20 Foot/pounds and ran the jam nuts. That was a mistake. The one that did turn ever so slightly without holding the set screw end up pulling the adjustment too tight. So it created a lopey / rough idle on my truck when hot. Later when I check the lash again I couldn't get a 0.010 or 0.008 in the intakes on a few cylinders and 0.020 or 0.018 on a few exhaust valves. After re-running and taking my time it fixed the lopey / rough idle.
It's an adjustable boost elbow. You turn the screw in to help keep the wastegate closed longer in turn building more boost. I would suggest checking that screw for boost leaks as well. Were the injectors new or used when you installed them? I didn't look back in all the threads to see but if they were used I would recommend getting them re-popped.
59 minutes ago, Mopar1973Man said:
I'm sure he would like to just... :spank:
The thought has come to mind. I think have RV's rebuilt and put them back in for now. They were pretty clean with the Comp until I make another swap over. The Banks was good power for me at the time. But it sucked when it died. Lost all but my fuel pressure gauge. Remedied that one though with stand alone gauges. The Comp was a big step up and then like you say the Quad came out not long after I bought the Comp. Just my luck. The good thing is I got to watch ya'll work a lot of the bugs out. So for now we tide with the Comp.
Brand new from DAP less than 1k milesnon them. Yea I’ll crank that screw up tight.
2 minutes ago, Marcus2000monster said:
Need to reinforce my leak tester cuz it kept blowing off but I didn’t find anymore. Pressured to 20psi
My tester will do that too. I just put a piece of wood between the end and something solid on the truck, Keeps it there. Dont forget to check the turbo and intake manifold cover.
