- Replies 71
- Views 8k
TheGreatWhite 27 posts
JAG1 8 posts
notlimah 5 posts
trreed 5 posts
Are you sure it's not 3k, 300k puts it at 110,000,000 a year that's a quarter of the US with all immigrants included. And just FYI more people die from blunt object strikes like hammers then guns but
CR Injectors just assume to have $3,000 ready every 100k miles. The last truck I had her at 112k miles it ate the engine. Numbers 5 and 6 ate the pistons and rings. Won't run but required
I don't think it's a common enough occurrence to worry about, and if it does happen put it gear and slam on the brakes :-)
I saw a video the other day thats been going around on Instagram, of a single cab newer Duramax running away and I got to thinking..... That is the 5th video I've seen of a duramax running away and blowing itself up in the last 6 months or so and I havent seen a Cummins (unless someone was tuning a VE) or a PowerJoke run away and grenade itself. Is this starting to be a common problem with them? Are the Borg Warners that they use a bad turbo? What do you guys think? I just see it as another reason to NOT buy one and another vehicle to Cummins swap.
