New Tire Size found 235's to 245's
I just got a pair of used 245/75 R16 tires from a friend. So I mounted them up on my old aluminum mags and mount the 245's on rear axle of the truck.
They are a bit shorter in height. The gains are great!
Engine load is reduced by 5% to 10% roughly.
EGT's are about 50*F lower.
Acceleration is way better and faster.
Cruising RPM's are right about 1,960 RPM at 65 MPH.
I've got to reset my cruise timing limit on the Quadzilla I need to drop from my current 25% to 20% it was holding cruise timing climbing about 2-3% grade.
I'm going to document MPG usage as well in the coming days.
  • Replies 264
  • Views 52.8k
  • From reading all this it boils down to what you are doing with your truck. For me I am mostly empty these days and cruising on the 265's at 75 netting me near 20 mpg. When I tow I try to stay  near 65
  • Scottfunk
    Scottfunk
    I just had the best luck at the junkyard today! I scoped out a Dana 70 that was under an E-350 last weekend that, according to the BOM tag, was a 70-U with 4.10 gearing. I studied up a little on it ov
  • Tractorman
    Tractorman
    I have now driven over 1,600 miles with the 245/78R16's and I am very happy with the results.  About 700 miles of the driving has been towing within a 60 mile radius ranging from 15,000 to 19,600 lbs
Isn't the 245/75R16 what is spec'd on the tire data sticker in our doors? This is the size I have on my 2 wheel drive '97 and I definitely like the acceleration of it compared to my 2001 4 wheel drive with 265/75R16.
Edited by 04Mach1
Yeah, it is the door sticker size. Mine was sold with the 265's from the factory. I opted for the 235's to reduce steering wear and front axle wear. Which it did. Now I'm looking to gain a bit more by changing the ratio up. Instead of like 99% of the people here that go bigger like 285's, 35" inch and 37" inch tires I found that with 3.55 gears and 245's is an awesome setup.
Here is a tweak I'm going to do to the 1996 Dodge. I found out it was manufactured with 245's as well but I'm going to switch that truck from the 235/85 R16 to 215/85 R16. That is the same as 245/75 R16 just an inch narrower. This will improve the MPG's on that truck and give better performance on snow-covered roads. That truck is about 2,000 pounds lighter than my 2002 Dodge and the wider tire tend to make it float on top of the slush and snow. The cruise RPM on that truck is too low and it struggles to pull in 4th gear.
Yeah. 245/75R16 is definitely the sweet spot for 3.55 ratio. The old 12 valve can get 30+ highway mpg if I behave and keep it at 65 mph. The 24 valve with 265/75R16 will get 23-24 mpg if I baby it at 65 mph and treat the throttle like there is a raw egg under it. Both have 3.55 gears.
I paid an upgrade charge for the 265's when I bought mine. Just another option. I had the 245's on my 96. It had a V10 so no good comparison.
@Mopar1973Man which engine do you have in the 96?
Been doing some looking for a half ton. Finding a lot 318's, several 360's, even a couple 6 cylinders. The only 360 I ever had was in a 1 ton 15 passenger van. That got  almost as bad a mileage as my V10. Of course it was pulling a good bit more weight and not very aero dynamic.
Talk about a huge difference 1 inch of tire makes.
EGTs are lower.
Engine load is lower.
Transmission temp is lower.
Exhaust brake performance is better.
Brake performance is way better.
Can hold 5th gear wider speed range.
Acceleration is quicker.
Less stress on the clutch during launch.
Just in the 120 miles I'm loving 245's over my 235's. Very impressed with the changes. Now I'm having hard time understanding people with 35 or 37 inch tires with 3.55 gears. I'm going to start fuel logs on my next tank.
Your aerodynamics have to be improved as well with less rake. Keep us posted!
Well just got full tank of fuel. Got to make it home yet. Then I've got 4th July party in McCall tomorrow. Then back to Ontario, OR on Saturday.
1960 RPM's at 65? Wow! The Chummy cruises 1860 RPM's at 80 with 265/70 r17. I guess the sixth gear (.61) in the Allison really does keep the RPM's down. Thank God I don't pay for my own fuel anymore! Sounds like I'll be in the market for some 3.73's when i jump up a couple sizes in the rubber.
23 hours ago, trreed said:
@Mopar1973Man is this considered a reverse level kit? :whistle:
Yeah, and it might be fouling my MPG numbers. Your comment stuck in my head and I happen to notice its leveled out. Lost the natural rake of the suspension.
You’re essentially running a 1in level kit up front. Bet if you had all 4 tires the same size you’d see the benefits you’d want without loosing the rake.
Realizing that now. Still, in all, I love the final ratio it way better. This truck screams now. I had a 4th gen attempt overtake me on a merge and I outran him. No problem put a 4th gen truck in his place behind me. Acceleration is wicked fast now. Then caught up with a friend for lunch down in Payette and we left together I tried to power through a left turn from a light and the tires let go really easy. Sure is amazing how much more power can be put to the ground by ditching ONE INCH of tire height. I know why the traction sucks are actually two-fold. One is the tires are extremely old and the rubber is really hard. Then the other part is I did not do the math on axle weight to tire pressure so I'm most likely overinflated.
Still sit here and wonder why the 35-inch and 37-inch tires are so popular. Steal the power, put more stress on driveline and transmissions. Etc.
Some people just wanna watch the world burn :evilgrin:
I surprised you can even notice any difference in the rake. The over all size being 1.2" smaller would only amount to lowering the rear only .6"
Edited by dripley
You do notice that the nose feels high like the hood got a bit longer visually. Nothing super noticeable but still feels different.
I could definitely notice a difference when I went from a 2in level to 1in level so I’d assume it’d be the same if the back was lowered.
I have never messed withe rake except hauling the 5th wheel. Other the my headlights aimed a little higher I don't notice a difference then. I know I would not notice 5/8". Just me I guess.
