Hydro boost or master brake cylinder
I’ve been having problems with either my hydro boost or master brake cylinder. I press my brakes and it seems hard put press a little harder and they work. But now my power steering pump is starting to hum. What could be causing this issue?
When was the last time you flushed the power steering fluid? (Suppose to be flushed every 30k miles)
When was the last time you flushed your brake fluid? (Suppose to be flushed every 30k miles)
Remember the power steering system has no filter so any debris will start plugging up ports and orifices in the hydro-booster and steering gearbox. Brake fluid is hygroscopic which means it will pull moisture from the air. This typically starts the process of rotting out the master cylinder and calipers (wheel cylinder if you got them). Then the rubber starts to degrade as well. This is why fluid turns black. Power steering and brake fluid is not a lifetime fluid then should be changed on a schedule.
Oh boy this might get really interesting.
I would start with the power steering fluid. But I've got little hope for it to do much good. Basically, the best thing to do would pull both steering gearbox and the hydro booster and get a rebuild or seal kits and full take them apart and clean them out. I'm going to bet the two parts are full of sludge.
If you want to do flushing you might as well buy about a gallons worth of standard power steering fluid (NO ATF). Then disconnect the steering gear box return hose from the back of the pump and plug that port on the pump to keep the fluid in. Now route that return hose to a waste pan. Now with the front axle off the ground, engine off, the key to OFF position not LOCK. Now cycle slowly from lock to lock. This will pull the fluid through the geat box and hopefully push out the debris and sludge if any. Keep filling the reservoir up and continue to flush until the fluid coming out the return is just as clean as what goes in. Now hook up the return again. Now cycle lock to lock with the reservoir full to push any air out before starting. The hydro booster is not much you can do but change the fluid a few times till the color looks good again.
As for the pump is if still making noise you might have a problem with either the hydro booster or the steering gearbox with something partially plugged up.
If you purchase any parts for the system make sure to blow all the old fluid out of the system before hooking any new devices up. Most will void the warranty if there old fluid or debris found.
I replaced the power steering pump. I flushed out the system but seems like it’s still doing the same. It might be the brake master cylinder I’m thinking. But now I have a major oil leak from the vacuum pump. I’m gonna have to order a seal kit and reflush the whole system.
Mine gets pretty hot also.
My hydro boost sprung a leak under the  hood now. So off it comes this weekend. I can now use the rebuild kit I bought a while back. Had a small leak under the dash and it quit, now I know why now.
I have a oil leak from they’re also. What part number kit did you buy?
