My NV4500 trans temps
4 hours ago, Dmaney said:
@KATOOM how heavy is your 5th wheel? I like your fast cooler setup and heat blankets, looks just like some of the stuff covering some of the steam piping at work.
14k - 15k toy hauler, depending on how much I have packed in it and whats in the tanks.
I agree with Moparman in that anyone concerned should invest in a temperature gauge just to understand whats happening at all times.  But that said, if you tow only in 4th gear you'll never have a heat problem. :thumb1:
I don't run a temperature gauge, but I do run fast coolers and have wrapped my down pipe. The down pipe being wrapped has reduced the floorboard temps so I am sure it has helped the trans temps too.
I'm not sure probe placement is as critical as some suggest since the fluid isn't stagnant when  you are driving. All the gears moving in there will slosh and mix it all around.
From what I have read overfilled transmissions run hotter than standard fill transmissions, and there are a couple theories. One is that the additional fluid does a better job pulling the heat from the gears/bearings so the fluid is hotter but the gears/bearings are cooler; and the other is that the additional fluid doesn't have the splashing inside the case and thus loses some of it's ability to cool and makes the gears/bearings and fluid all run hotter.
I think theory one is the most widely believed.
I know the NV4500 has some 5th gear nut issues and that started a scare for towing in 5th, but the NV5600 doesn't have that issue and can tow in top gear... As far as temps OD will almost always run the hottest. I've personally never heard of cooked fluid or bearings on a NV4500 or NV5600 and only a few cases with a G56 and ATF.
I'll continue to use 6th when I have the power to do so.
Just to be clear on my "overfilled" statement.....  The 4500 holds 4.25 qts.  The Fastcoolers hold 1 qt per side.  Therefore I have about 1/2 to 3/4 of a qt in there overfilled.  The way I read what I posted was 7 qts overfilled and I dont want anyone to think I'm running almost 2 gallons overfilled. :stuned:
I'd edit it but no longer can...
To cover all platforms. Direct 1:1 ratio is...
  • N5600 - 5th gear
  • NV4500 - 4th gear
  • 47RE - 3rd gear
For towing up grades this is the coolest gear to use. 3rd gear will enhance the heat because of the long time pulling the grade at a slower speed giving more time to heat up. 5th gear from pulling with high torque in a overdrive gear will create considerable amount of heat too.
12-hour window. After that, the system locks out the edit. Prevent members from thrashing their posts.
My intent wasn't to go over the deep end @Mopar1973Man! Just sharing some of my results and seeing what other members had observed to see if it was in line with mine, or close for that matter. For the record I'm on stock tires, 4:10 gears and factory fill level.
On a side note I may look into the heat wrap because the wife doesn't really care for how warm the floorboard gets on her side wile towing!
