47re trans cooler line at the heat exchanger leaking
I believe you need to be looking at figure 7-620 which is page 126 of the PDF parts lookup tool. At least thats the diagram of the tank that I believe your talking about. Although the lines will be in the other picture posted earlier. #2 and #6 will be the ones going under the bell housing. Part#'s 52028732AC and 52028633 respectively.
8 hours ago, Haggar said:
That picture is from the '01.  (scary i just noticed the picture is of a P-Pumped engine.... )
Anyway HTH
Hag
Take it from someone working for chrysler right now. I can look up common rail engines and newer stuff and still get a diagram of old stuff. Its kinda at random. Not sure why its like that but it would be nice if they were able to maybe at least make the diagrams accurate.
Edited by 2000Ram2500
If that fitting is bound that tight I don't think an easy out will work.  With the walls so thin It probably will just jam the threads of the fitting tighter into the case.
I would take a hacksaw blade, trim it thinner to fit in the hole with the teeth angled to cut on the pull stroke.   With the hacksaw blade cut grooves in the fitting at the 6 and 4 o'clock.  Cut only the fitting, do not cut the threads in the case.  When the two grooves are cut  take a pic or an awl and work that small slice of the fitting up and out. You might want to cut one more groove at 8 o'clock to make the next steep easier.  Once that peace is out you can then collapse the rest of the fitting and spin it out.
Take your time and be patient.  I've used this method several times over the years and it's worked every time.
No, That's a pressure line that comes from the l/u switch valve.  Use a magnet and brake cleaner spray with a straw to flush any thing out.
Any metal misses will go through the cooler and into the pan to be caught by the magnet in the pan or the filter.
Edited by IBMobile
You'd be taking so much of the transmission apart. Thats all above the valve body and i think even after that you wouldnt be able to get to it because if i remember right theres part of the casting still in the way which would mean removing the whole trans so you can pull it completely apart etc...
