- Replies 16
- Views 4.8k
Mopar1973Man 4 posts
Tractorman 3 posts
Dieselfuture 2 posts
IBMobile 1 post
Popular Days
I just did a clutch, I just used a bit of spray on graphite on the splines and throwout bearing . Dry lubricant so it won't hurt the clutch discs. Probably won't stay on very long but doesn't hurt an
I greased that sleeve on mine.
Yes that what I'm talking about there that throwout bearing has grease in the inside of the part that rides on the sleeve. Mine was already packed and ready. Slide it on and it automagically greased t
So last week my clutch went out and so I bought a new clutch for the truck (Southbend Single Disk Feramic clutch if anyone is wondering) and I threw everything onto the truck up until reinstallilng the transmission itself. Just got done packing the throwout bearing and input shaft (high temp wheel bearing grease) and I realized the clutch is in the truck and everything already and I don't want to take it out again to get greases in the splines since I was told there needs to be grease in the splines of the input shaft and to use the clutch to spread it in the splines and I assume get some in the splines of the clutch as well. Make sense? I hope it does because my question is do I need to lube the splines of the clutch when reinstalling the transmission if I lube up the input shaft good enough? Anything helps, thanks!
TL;DR: Do I need to lube the clutch splines at all or will it work just to throw some grease on the input shaft and install the transmission?
