- Replies 24
- Views 11.1k
Mopar1973Man 8 posts
Ravewolf 5 posts
Tractorman 3 posts
NIsaacs 3 posts
Popular Days
Twins yeah... Different story I'm only dealing with singles friction disc typically. (Rancher and construction trucks) Both versions can be damaged by forcing transmission with th
What bushing are you referring to? With the engine at idle (cold or warm) with clutch engaged in neutral (foot off pedal), can you depress the clutch pedal, pause for a couple of seconds, and then ea
This is why you can't judge the 50 WT transmission fluid as a cause being you've added more rotational mass in your clutch. Then blame the fluid. Very very common. Now if you had a single disc clutch
Like the title says, my transmission is hard to shift. Real notchy, and sometimes a bastard to put into gear or reverse. It's rebuilt, and has maybe 400 miles on it. Running Lucas 50wt oil as recommended. But it just doesn't feel right. In another post I stated I had the clutch pedal adjusted way our to get rid of the slop of no bushing. The clutch seems to release ok, it doesn't crawl when in gear. But I worry it's something else. I will say when I put the transmission back in I fought to put it in the last tiny bit in the pilot bearing. Had to torque it down, but I did it as slowly and gently as I could,and the gap was less than half an inch when I started. Not sure if it was hung up on air or just such a tight fit. Also has a Sb dd clutch, and had the big input shaft put in. Stock shifter. No noise from the clutches, and no noise from the transmission. But I can kinda feel the teeth in third sometimes, is this normal?
Anywho, tell me I'm paranoid and it's all ok. I'm terrified to blow up this transmission, or hurt this truck in any way. I waited seven and a half years to get another cummins, don't want to ruin this one.
