Newbie to IQuad V2 Display questions
int3man
Hi All,
              Well I got it started.  IQuad is installed and running and the MAP Sensor is working (Got up to 20 PSI Boost today on test run  :)  ).  So now I want to understand.
When IQuad starts it installs system setting every time it starts!!!
Can you change the background colors?   I want to make the numbers white and the borders for the numbers Light Blue.  It's hard to see, especially in bright daylight.  I have transition lenses in my glasses and they auto darken.
Thanks!
Michael
Edited by int3man
It does actually it is just a single byte command so you dont see it.
The load everytime is on purpose, so you can make tune adjustments without the truck connected.  then when you connect to test it will automatically update your changes.
IE you can tune on your couch and then go out to the truck and it will sync the settings in the currently selected tune.
