- Replies 32
- Views 16.1k
Blakehenryy 12 posts
Mopar1973Man 11 posts
Dieselfuture 4 posts
dripley 2 posts
If you keep replacing the crank sensor and get the same result then it's not the crank sensor. The ECM was good when tested so new sensor and good ECM then may be bad connector/wiring. I would star
I have a spear ecm programmed to my truck and if I use it my tack will randomly drop to 0 on cluster but in quadzilla it still shows rpm. It will set a 1698 code. Switch back to the other ecm and no p
It could definitely happen, this is not the first case. @dripley knows all about how to giggle a wiring harness. I believe there is a ground splice just before ECM, it's on my list to do also.
Just picked up the truck from a buddy, it’s a 1999 Dodge Ram 2500 24v Cummins. Sold it to me for a good deal with one problem code p0336 no tach, causing a lack of power. He told me he replaced the sensor with many different brands, and got them ecm tested and the tach worked on bench. The oreillys brand sensor works the best, works for 3 seconds and tach dies. He called a mopar friend of his and he told him to get a cummins brand crank and cam sensor. I got a cummins crankshaft sensor and tach didn’t move. Recorded live data from my code scanner and my OBD2 is able to read my RPMs, but nothing on the dash. I’m stumped
