- Replies 15
- Views 2.8k
ISX 6 posts
AH64ID 5 posts
guesswho512 2 posts
KOYOTE 1 post
There are several neat parts to this vid and I kept every part short and sweet so keep watching it if you hit a second thats boring
I ran the initial 2 stroke test by dumping the fuel filter and priming it straight off the tank of 128:1, so there would be no leftover fuel messing up the ratio. The engine was completely warmed up on all tests. So first off we have the comparison in sound between regular #2, 2 stroke@128:1, and 2 stroke@2:1. All of these test were right at 1000RPM with the camera in the same spot. Then we have videos showing return line rates and how it works. Then we have a vid of me showing how I got 2:1. Pint of 2 stroke and quart of 128:1 that is in the fuel filter should mean around 2:1.. So, I think there is a little difference between #2 and 2 stroke. I know you VP guys say you can hear the 2 stroke hit so I would like to hear that sometime. The fuel lines did not get very warm at all, I thought they would but since they don't really cool the injection pump like it does on the VP44 (oil does on my p7100), it makes a little more sense. I am surprised that you hear 0 difference between 128:1 and 2:1, just goes to show that 128 is plenty.
