No washer or intermittent wiper
Ronnie,
I have had them stuck before too....   Spray a bit of penetrating lubricant in there.  With the lock in the out position, I use some small pry bars, and slowly and carefully put some upward pressure on each side of the wiper arm. Wiggle, pry, wiggle pry, spray more oil.  Eventually it will slide off.  Some of the issue is the wiper arm is to one side, so when you try to pull, you make a rotating movement and the splines don't want to separate.  The trick is even parallel pressure.
HTH  GL
Hag
Ronnie,
I hope they come off for you... they can be a pain!!!   You may want to try a little bit of heat too, if you have a heat gun (or just a hair dryer.)  this also may help working some penetrating oil in there.
In the old days of US cars, the wipers had a center bolt.  So you could use a special puller (like a gear puller) to get the suckers off.....  Hey just think, this (the new clipped slip ons) saved a good 3 minutes per vehicle during manufacturing!!!!  It doesn't matter that it is a nightmare for you now!
Hag
  • 2 months later...
On 4/1/2019 at 11:33 PM, 98whitelightnin said:
Did you ever get this issue resolved? I put in a new motor today but still have no intermittent mode. Can the CTM be swapped with a junk yard unit easily?
Sorry just seen this my issue turned out to be a failed column switch I think you guys call the a multi function stick? Hope this helps!
