AirDog Toggle Switch hardware
4 minutes ago, tmropr1991 said:
Ok that's something I could think about doing too. Because I need to figure out another place to put it. I could run a hose from that tap to the front of the truck and put my sensor. Somewhere more accessable as well
I have one of these in the 1/2 inch fuel line under the hood with the snubber screwed into it and the fuel pressure sensor screwed into the snubber.
https://www.dieselautopower.com/vulcan-push-lock-fuel-pressure-tee-1-2
Yeah...
That's the problem you need distance from your last snubber to allow the remaining pulses to fade out.
1 hour ago, tmropr1991 said:
So it would be on the fuel line leading up to the injection pump?
This is mine for a mechanical pump. It has been like this for 8 years. I still use my factory filter.  I cannot see any harm in the gauge tap being at the pump with no filters after the tap for the gauge. This is between the factory filter and VP.post-10340-138698208787_thumb.jpg
Be aware... Now with mechanical gauges typically there is 5 to 7 feet of tubing between the tap point and the gauge. Now with electric gauges you need the same amount of tubing distance as well. A lot of people just screw the sensor directly into the tap point. This is wrong. You need to have that 5 to 7 feet of tubing yet this what allows the pulses to fade into the distances of the tubing. Still need a snubber too..
I have the snubber on the sensor right now but I bought the fittings to put hose from the tap on the pump all the way up to the engine bay to put my sensor at the engine. So should I still keep the snubber at the sensor or put it at the tap for the pump?
