HELP! Flashing Wait to Start Light
14 hours ago, dripley said:
Forgot to attach the photo.
21 hours ago, dripley said:
Is this the ASI you are speaking of? I keep this as a reminder of the debacle I went thru with them back in 09 or 10. The first one tripped 606 code and the truck would not run. They kept my core charge and it took 6 additional weeks for them to send me a replacement. It only lasted a year before it left me stranded on the side of the road. Cruise never worked on it either.
Yes that would be the same ASI. I will steer clear of them.
ECM was shipped to ACS yesterday.
Got the truck home on the ECM from the 2001. In the meantime will be testing for AC noise and doing the ground mod.
I'll report back once my repaired ECM is returned. The OCD in me stamped the case of my ECM with the last four of my VIN to see if I get my ECM back or one that was already repaired.
So I picked up an Innova 3320 since my Craftsman multimeter was too basic.
Started the truck cold and the grid heaters were kicking on and off. Both batteries were at 14.24 volts at idle.
For AC noise I got intermittent readings of .017 to .019 and then I would get .048 to .051. I'm not sure why the readings would fluctuate. But with those numbers I'm assuming the alternator took out the ECM.
8 hours ago, dave110 said:
Readings get higher when the grids pull a load on the alternator. If written correctly your readings are very acceptable. Not many see as low as .017.
It was definitely .017 to .019. I guess my ECM just died from age. @Mopar1973Man
Edited by gipperkid
@Mopar1973Man @pepsi71ocean @IBMobile Just got an update from ACS. My ECM is done and on the way back, due to be delivered tomorrow.
Their findings report I am somewhat skeptical about seeing as how I drove my truck home on another ECM. Which I guess the "short" was actually the AC noise. Here is the email they sent:
"Great News!  Your unit has been completed.
Tracking number is- UPS 1ZR39F470354941703
Tech Notes: PLEASE READ BELOW ( there is a short in vehicle )
Our findings: You unit came in shorted out, your... unit arrived dead, APP pedal, lift pump circuit, CPU as well as your pins were reflowed. New flash chip as well as latest updates ( your engine wiring harness is in short!!!)
Prior to installing repaired unit: You must have repaired your short. Do protocol maintenance prior to installing the unit ' wiring , battery & terminals, alternator, sensors, etc... Please tend to all codes present, if there are ANY p0600 to p0609 codes please MUST replace batery & terminals prior to installing unit. All short in vehicle must be repaired. If there are any TSB (Technical Service Bulletin)  they must be tended to prior to installing unit. Make sure all parts replaced are OEM(Original equipment manufacturer) parts are a MUST! All Problem in vehicle must be tended to prior to installing unit ( failure to do so will result in damage to the unit and it will not be covered under warranty).
As a valued customer of ACS, we want to make sure all of your inquiries are handled in a prompt, professional manner.  Please send all question or duplicate invoice requests to autocomputerspecialist@gmail.com.  This mailbox is monitored and administered by several people in the sales department.  In the event that someone is out of the office, all emails will still receive direct attention.  If you have any questions or need assistance, please do not hesitate to call.
Thank you choosing ACS have a great day!
ACS"
  • 3 weeks later...
UPDATE!! Finished the ground mod last night and installed my repaired ECM from ACS. Truck started and runs fine, did not have time to check AC noise but will do so tonight. I did have a check engine light. With the key trick I got P0230, P0382, P0380, P0521, P0118, P0113, P0237. But dummy me didn't disconnect the batteries when I unplugged sensors and the alternator for the ground mod and I'm guessing using the wrong ECM threw some codes as well since one of the codes was for oil pressure. But on the second start the CEL was off. So far only have driven 30 miles and no issues. Thank you ACS
  • 6 months later...
On 4/24/2019 at 6:42 PM, gipperkid said:
@Mopar1973Man Just tested ac noise.
Passenger battery:
Max .010 at the terminals.
Max .016 at the alternator post.
13.92 volts at idle on hot engine
Driver battery:
13.90 volts at idle
did you have a chance to check out the Reman Mintt ECM?
