1 minute ago, Mopar1973Man said:
Most here go for the 62/68/12... My 60/60/12 HX35/40 hybrid I grabbed it for the fact I didn't want to lose my exhaust brake which most aftermarket turbos you end up losing the exhaust brake (turbo mounted) then moving to in-pipe exhaust brake.
A lot also depends on where you want your best rpm range to be.
60/60/12 will do best at lower rpms, such as towing in higher gears. The 62/68/12 will do better at higher rpms, such as racing, or more "spirited" driving.
Edited by AH64ID
