OEM & Aftermarket
Experience with buying 3-4 mechanical lift pumps for a 92 12 valve I had for years showed Cummins sold me the same cheaper part that the auto parts sold and was not the original well made lift pump, only a higher price with better cardboard box to make you think it was better.
Next run to Cummins revealed a well made, in U.S.A., Vibration damper needed for the 01. Much better built than the aftermarket lighter weight damper available from Dorman. I do not like Dorman quality anyway.
Edited by JAG1
Done some digging and getting closer.
Robertshaw manufactures that style of thermostat.
Cummins...
cummins-3946849
Robertshaw 330 series looks almost the same. Commonly used in racing applications still sold through Summit racing.
Related image
Now I'm trying to find a contact information for Robertshaw Automotive division. Then to verify the thermostat Cummins has to Robertshaw number if possible. These thermostats are sold for a mere $20 on Summit. This might be the break where Cummins owners could buy $20 thermostat from Robertshaw WITHOUT the Cummins logo and $40-60 price tag.
On 8/7/2019 at 4:28 PM, Mopar1973Man said:
Another one, I was told by Eric @ Vulcan Performance to just call Cummins Dealer and order crossover tubes. OMG! $420 bucks for all 6 connector tubes. I refused to pay the $70 a piece price for Cummins logo'ed crossover tube. I had Eric order the set from his supplier took a huge savings.
Just few example of wasteful spending just for OEM parts.
Genuine Bosch tube from DAP $25.00
https://www.dieselautopower.com/bosch-cross-over-fuel-connector-tube-f00zr20002
Again still WAY CHEAPER than Cummins OEM at $70 dollars a piece.
Yes, but I think the point of this thread was finding the oem manufactures and buying direct for cheaper. I don't know for a fact, but chances are Bosch makes the tube for Cummins and Mopar. Just helping out.....:thumbup2:
Thanks, but kind of late.
I called NAPA locally they claimed they had no listing for a oil cooler gasket. Figures... Most likely a greenhorn parts person.
Mopar dealer and Cummins dealers are the worst for price and have the highest absolute price. Which 99% of the time I'm sure you can buy the very same part for a fraction of the price elsewhere.
Tidbit more.
@mr.obvious did a bit more testing. He put both Cummins old thermostat and the new thermostat in a pan of water and heated. Watching they both open exactly at the specified 190°F as stamped on the thermostat. The problem is when left to cool the new Cummins thermostat is EXTREME slow to close back up taking up to 3 minutes. The old thermostat only took a mere 30 seconds or so. This explains why the the new one is running cold sided.
Not even one month old and failed on my previous post. I'm 90% sure this is a Robertshaw 330 high flow thermostat and produced by Mr. Gasket of all weird companies.
Just to show this failure is common to split the body from the disc.
48218555d1508873004-new-robert-shaw-ther
Image result for Mr Gasket robertshaw thermostats
Just to show this design is used by Chevy 6.5L Diesels.
https://www.napaonline.com/en/p/MRD385190
So here we are Cummins does not produce the thermostat. Mr. Gasket does using Robertshaw 330 high flow design. Common to split apart in different applications. Just as @mr.obvious thermostat failed in his 2002 Dodge Cummins. So is it worth the $40 to $60 price tag to find out you have a part not even a Cummins part just reboxed Mr. Gasket. I've call Robertshaw and they do not acknowledge that they sell thermostats. This is when I found the tie to Mr. Gasket who is currently producing. As I said I'm 90% sure of this.
