13 hours ago, IBMobile said:
Here's the build sheet and I upgraded the torque convertor to a Goerend 15SS
Air temp 91°F  Transmission fluid temp 165°-190°F
Line pressure, transmission in drive :  no throttle  stopped   85 PSI
                                                          light throttle  2ed gear 105 PSI
                                                          light throttle  3ed gear  110 PSI
                                                          light throttle  4th gear   120 PSI @ 2200 RPM
                                                          W/O throttle  1-2 shift   180 PSI @ 2800 RPM
                                                          W/O throttle  2-3 shift   175 PSI @ 3100 RPM
                                                          W/O throttle  3-4 shift   150 PSI
                                                          W/O throttle  4-3 shift  150 PSI
                                                          100% throttle 4th gear TCC locked @ 70 MPH 160 PSI
                                                          0% throttle 3ed or 4th gear TCC locked down hill slowing 100PSI
                                                          reverse gear stall test 330 PSI
This transmission is putting power down that was wasted with a stock build.  I now have the power to the tires to brake them loose or tow my 5er with the boat behind it up an 8 mile 6% grade at 65 MPH with throttle to spare.
Thanks Jon.
That looks to be a list of parts I could do with, I doubt I could jump on a trans done then shipped as the damn shipping and customs would be huge also the core charge is a killer but the parts I could do
OK. I see what he's referring to now.
Yes, they do have kevlar fibers in the weave, but the Pro Series is a high-energy woven carbon style band. It's not what is typically referred to as a "kevlar" band. That's where I was confused. Either way, they're a great band! LOL!!
Carry on.....
