Front brake dust shields
1 hour ago, dave110 said:
Apparently the PO never heard of never seize.
Been nice had Dodge knew about anti sieze. I gave every thing up front a good coat of anti sieze the first time I got mine apart. Had to use a small thermo nuclear device to get them off.
  • Haha 1
5 hours ago, Mopar1973Man said:
My last trip on wheel bearings my air chisel tool did NOT work at all. I spent over 4 hours with a very larger hammer getting the driver side bearing out of the knuckle. Make sure to anti-seize the bearing hole and use a hone tool or similar to clean the hole up. The bearing should fit true but not sloppy loose.
I used two impact sockets and impact extensions while holding them, and had my brother turn the steering wheel. I did it in cross cross pattern and they came out in about 5 mins. engine not running. Just nice and quick.
Yup its known secret. Work smarter not harder.
No beating involved. Ok I did learn on the second bearing
The first one I cried alot attempting to remove with a sledge hammer.  Wtf is holding this on I kept asking myself.
Edited by Evan
This is by far the best trick...except I cranked the motor and let the power steering do the work.  I didn't even get in the truck...just stood next to it and reached in with one hand to bump the wheel.  My brother is completely worthless so I did it all myself.  I changed to the freespin lockable hubs so I'll never have to do it again... :woot:
21 hours ago, Evan said:
Use a socket and short extension and trucks steering system to knock bearing loose.
Back bearing bolts off a 1/8" or so turn knuckle and wedge socket and section against axle
Had to the first time. No need to after never seize.
