Oil Pressure Sending Unit
Have you tried re-seating it? Do you know if you have the ECM flash that makes the oil psi gauge fake? If so then I really don't think it matters what psi sender you get, as long as it shows pressure where there is some the ECM won't care.
So if I get the flash done to take advantage of the high idle 3 cyl run my oil pressure gauge will not work correctly?
That is my understanding.
Umm.... I've got the flash and mine seems to work fine....???:shrug: I don't have another one to compare it to, but it seems the same before and after the flash!:thumbup2:
What does your pressure read? Cold cruise should be about 80 psi, and warm idle is down at 20ish, normal cruise is about 55-60 at 2K rpms.
That sounds just like mine.:thumbup2:
When did you have the 3 cyl flash done? I have been under the impression that the 3yl flash is an actual SW flash, but maybe its just like the 3rd gen and its not a full flash, just an enabled option. But then again its also just my understanding that all current 2nd gen SW make the oil psi gauge fake, but maybe thats just an 01-02 thing as they seem to have more options and bigger ECM's. But you have an 01, so :banghead:
Actually there is a difference... High idle is a flash yes be there do not reprogram the ECM/PCM at all all they do is ENABLE the high idle function and that all... As for taking a software update then you end up with all the goofy problem hence the oil pressure gauge become a idiot light.
That explains it!
So if I hook up a smarty what does it do? I was wondering if there was anyone close to me central Illinois who has a smarty and would be willing to hook up and do the upgrade. The local Dodge dealer has no idea what I am referring to when I asked about the fast idle 3 cyl unlock, makes me apprehensive do not want "all the goofy problems"
A while back, not sure about the date. Mike explains it all!!!:thumbup2:
That's how I got mine done I had Bob Wagner send me his personal Smarty and I got to play with it for a couple of weeks and the just return to stock and mailed it back. Thing is either way is safe going to the dealer or using the smarty... If you can't get a smarty then got to this page... http://mopar.mopar1973man.com/cummins/2ndgen24v/high-idle/tsb18-019-01.htm Print it out and then take it to you local dealer they can follow the step by step instructions to enable the high idle. Just follow from #7 down...
