1998.5 2500 lopes and dies
I've been having trouble with my 98.5 2500 for sometime now. I go to start the truck and it "lopes" about 10-12 times and dies. I have no throttle response when pressing the pedal while it does this. I have replaced vp44, crankshaft position sensor, camshaft position sensor, throttle position sensor, grid heater relay, I have newer batteries, also cleaned the grounds really good in the batteries as they had a little bit of corrosion on them. When I turn the switch on it takes a couple of seconds for the WTS light to come on, when it comes on i can hear what I believe is the fuel pump priming. WTS goes off and I start it and it does the 10-12 "lopes" and dies. Any help or advice would be greatly appreciated, thank you in advance.
Edited by Kosmo
  • Replies 7
  • Views 2.4k
  • Update...had to ecm repaired and everything is working normal. Also installed the quadzilla adrenaline while I was at it. I am pleased with the results. Thank you guys for the advice.
You need to scan it for trouble codes. That will help point us in some direction. The delayed WTS is an ECM issue. But thats another expensive part to just throw at it and hope it works.
Edited by dripley
ECM damaged... Time to rebuild it first. Now also do the W-T ground wire mod and the alternator protection fuse too.
I have scanned it for codes and the only thing that showed was grid heater relay, nothing else. It isn't throwing a check engine light either.
Forgive me for being a noob, but I'm not sure what the W-T ground wire mod is.
It's a sticky at the very top of this particular part of the forum.  I'd be checking for codes with a newish snap on scanner do you know anyone with one ? and see if that can communicate with ecm... WTS light is ecm though
Edited by wil440
Thank you guys. I'm removing the ecm and having it repaired. I will update when I get it reinstalled.
Make sure to do WT mod and check your alternator for AC noise before you cook another one.
