Pristine CTD. Extra cab, short bed, 2wd, SLT. Factory tow/haul package, leather heated seats, heavy insulation package. Rebuilt HX 35/40, Dap injectors, full gauges, PacBrake, Dynamic Transmission vb/servos/accumulator/strut/band/triple disc. Soft tranny lines, 40k trans cooler, lift pump, gooseneck hitch (never used), class 5 tow hitch, tonneau cover, air bags, re- geared to 3.73’s, 3rd Gen brakes with 17" rims Rust free CA truck located in Chico CA, 100 miles north of Sacto. I built this to
Price: 16000
I need help here. I have a 2001 with the 6 speed. The clutch went out a couple weeks ago so I decided to do some long overdue work on the truck while tackling the clutch job. I put a new south bend dd in and a new slave cylinder assembly. I also changed the drivers fender as well and pressure washed the entire engine and undercarriage. The truck ran perfect when I shut it off to do all the work. I have the air dog 2 with a 2 year old industrial injection vp44. I've always had 20 psi fuel pressure at idle with about 17 at WOT. When I got everything back together and started the truck, it idles perfect but it won't rev above 2000 rpm and started defueling causing a missing and backfire around 1600-1800. It pours black/blue smoke like it's tuned but it has no programmer. I also had a horrible sudden fuel leak from the connector tubes so I changed all the orings and fixed that problem but still there was no change to the engine sputter and defueling. I ran the codes and had these codes P0234 p0113 p1698 p0251 p1287 p0252. I can't help but think I'm missing a ground somewhere or have something wrong or wet but can't figure it out. I have a hard time believing that the IP just quit at the same time I did all of this work. Any help would be appreciated.
