NV 4500 Removal
40 minutes ago, Haggar said:
That is why it won't just drop out.   Both of the above suggestions work to remove it.  The taper is why you have to do it that way.
I learned that when I did my clutch job.  I used a bottle jack and a board to spread the frame for removal.  Then I studied the frame and I realized that the jack wasn't needed and I re-installed the crossmember without the jack.  Somebody told me a long time ago...  work smarter, not harder.  Every once a while I exercise that option, but not too often - I don't want to overdo it.
- John
Edited by Tractorman
  • Haha 1
I went through ECD 727.00 Flywheel and all, 375hp basic stock. The old clutch, I should have left it in and ran it. The pilot bearing was perfect, throw out was in good shape and the clutch, I'll put a caliper on it and let you know. One question, what would you lube the splines with on clutch? What ever I used back then still looks good I wish I could remember.
