- Replies 57
- Views 8.3k
dieseldon 26 posts
Mopar1973Man 10 posts
LorenS 7 posts
Me78569 5 posts
Thanks, just did the ground mod a month or so ago. All grounds and connections look good, clean, etc. Fixed my shift wandering!!
Have you tried bypassing quad and putting all wires back to factory. if you do that and it works fine then there is an issue with the quad. You could try reflashing v2 software on it if you dear. It's
Ok... To verify sensors. Setup your iQuad app and have ready in the morning. On the display have coolant and IAT right next to each other. Now when your turn the key on for the wait to start just done
Wondering if anyone else has issues with
"Daily driver with meat" tune?
It was running awsome for a day or two, then things took a turn for the worst. Started idleing around 3k too high, hard starting, 5-8 seconds of cranking (usually fire's right up with just a blip of turn key) check engine light, 0500, 1693, sitting at a light whilst in gear it would surge randomly and try to take off!
Switched to a different tune and seems to go back to normal?? Honestly haven't driven much since. But lights out and idles normal.
On another note, if anyone in Boise area could help a brother out who has experience with the quadzilla and maybe help me dial this thing in, fine tune custom tunes, settings, sensor warnings, etc.
I'm new to this iquad and diesels in general and this is just overwhelming!! Plug & play? Kinda? For a diesel newb, nope.
Thanks for any info/ideas.
