- Replies 14
- Views 2.3k
Max Tune 4 posts
Mopar1973Man 3 posts
dripley 2 posts
Dieselfuture 2 posts
Popular Days
I'd get a mechanical one if you're getting a new pump, jmo
I feel your pain. Gravel is all I have too. Plywood does make it easier on the body.
If you have a bed mounted fifth wheel or gooseneck, bed tilting is a no go unless you like removing and reinstalling those mounts. If no bed mounted hitch, the following will work:
Driving home today and my fuel pressure went to zero instantly. Been noticing fluctuations in pressure. Changed FF and WS a month or so ago and had same issue. Going to check it out tomorrow. Have also had an issue with losing pressure at half tank. Think the draw straw may have an issue so I plan on lifting the bed. Is it better to tip it from the cab end, leaving bolts loose in rear or tip it from driver's side leaving bolts loose in passenger side? Don't have help available to fully remove bed and tank was filled 40 miles ago so don't want to remove it.
