- Replies 16
- Views 7.8k
Mopar1973Man 5 posts
Blueox01 5 posts
Haggar 3 posts
NIsaacs 1 post
Now today brake pedal seems fine, all day.
Sometimes the output rod length to the master cylinder is off. Some are adjustable, some you may need to grind shorter. What happens is they can hold the master cylinder down slightly.
Sound like something wrong in the hydroboost to go both ways. Like the spool value is stuck why the brakes are lock. I'll keep my hydrobooster and just rebuild it. Already done one. Not ba
Originally I had a power steering fluid leak, found a line I thought was leaking, replaced, still leaked, replaced other line just to makes sure, ended up finally seeing Hydroboost leaking (didn't have a brake problem) Replaced Hydroboost, then intermittently pedal would almost go to floor, so got another Reman Hydroboost, now it's locked my brakes up, unless I'm doing something wrong it's going to be #3 reman going on this am.
