Coolant leak at the back of the head
- Replies 25
- Views 6.8k
Dumb A 8 posts
Mopar1973Man 7 posts
dripley 3 posts
IBMobile 3 posts
That's what I normally do, keeping my engine compartment and vehicle clean. That way you can see new oil leaks and things going wrong, hopefully keeping ahead of problems...
I typically use the Zep or HDX brand degreasers. Being acid based it works great on wheels and brake dust. Cut thick grease typically in one or two passes of degreaser being sprayed on. Slightly warm
Help from the wizards please. I have a coolant leak dripping from the back of the head running down the bell housing. I stuck a small mirror back there and I see a sensor bubbling around the ceramic center. I tried to identify the sensor in the service manual, no joy. This sensor is screwed onto the head, water jacket at the aft end of the head between the head and firewall, thanks!!!
