- Replies 14
- Views 4.3k
Alexio Auditore 4 posts
Mopar1973Man 3 posts
Royal Squire 2 posts
Tractorman 2 posts
Popular Days
Mopar 1999-2002 flasher relay part number 5600748, new number 68499015AA. You can contact your local Jeep, Dodge, Chrysler parts department for availability or check these web sites below.
The OEM flasher requires a specific electrical to pass through the unit. The purpose is to let the driver know if a bulb is out (electrical load is reduced and flasher will flash rapidly) The heavy
After thinking my blinker issue was due to the multifunction switch, I figured out it was the relay.... so another 20 bucks later and I picked one up at Napa...and I hate it...
It sounds really dinky....and has a slight delay from when I turn the switch on to when the blinker starts to flash. Is there a relay that sounds and functions like our stock ones do?
The only other thing I'm trying to do is sand the copper contacts inside the older relay to see if it will start working again properly....it blinks and then stops, then will randomly start blinking again, then stop...
Obviously this is not a serious issue, but when you are used to something for almost a decade and then it changes and sounds cheap...well you know...
