P0122 Low Votage to APPS
Hello,
I have a 2001 Dodge Ram 3500 5.9 4x4 5spd. I started having a dead pedal and surging issue a few days ago. OBD reader shows low voltage to TPS. I used mikes diagram and made it to step 9 and I had continuity with the PCM and ECM orange and dark blue wire. It’s saying repair short to ground in the orange and blue wire. I checked all of the grounds to the ECM and PCM but I’m not sure where to check for the orange and blue grounding. I would appreciate any help that you guys can offer. I’m not a very good mechanic and no one in my area can even get
my truck in the shop until September 15…
Edited by Jeff Eady
I went thru pretty much the same thing a few years back. I replaced my battery cables and did  WT's ground mod. Already had a Timbo apps. All that cleared mine up. This trucks are very picky about their DC power supply. And they dont play nice with alot of AC noise.
WT ground wire mod is quick about an hour job to split the loom open and mkae the new connections. You just need the crimps for the wire and then a 150A circuit breaker or fuse for the alternator charge lead.  I've done three trucks now, my 2002 Beast has this mod too.
